Missing metrics / panic: duplicate metrics collector registration attempted
I want to expose Prometheus metrics on :9090/metrics.
The docs say to enable metrics in the global settings.
But then it either panics, or exposes too few metrics.
If I remove it servers, it doesn’t panic, but I get very few metrics.
I assume it panics because I listen on several ports and it tries to attach to each.
It doesn’t panic with the following, but it also doesn’t expose the metrics, and admin exposes very few metrics.
	servers {
		metrics
:8080 {
	metrics /metrics
	respond "Hello"
curl -s localhost:8080/metrics
Hello
curl -s localhost:2019/metrics | wc -l
20
Also, this sentence is not true:
Metrics must be turned on in your global options first.
v2.9.0-beta.2
Docker
	servers {
		metrics
:9000 {
	respond "Hello"
:8080 {
	respond "Hello"
This is a known issue in the beta and was fixed here
The fix will go out with the next beta
Thanks, using master solves the error.
But am I supposed to be seeing more metrics than this?
Several metrics are mentioned in the docs that are missing here.
Like caddy_http_response_size_bytes for example.
# HELP caddy_config_last_reload_success_timestamp_seconds Timestamp of the last successful configuration reload.
# TYPE caddy_config_last_reload_success_timestamp_seconds gauge
caddy_config_last_reload_success_timestamp_seconds 1.7297037920974286e+09
# HELP caddy_config_last_reload_successful Whether the last configuration reload attempt was successful.
# TYPE caddy_config_last_reload_successful gauge
caddy_config_last_reload_successful 1
# HELP caddy_http_requests_in_flight Number of requests currently handled by this server.
# TYPE caddy_http_requests_in_flight gauge
caddy_http_requests_in_flight{handler="metrics",server="srv1"} 1
# HELP go_build_info Build information about the main Go module.
# TYPE go_build_info gauge
go_build_info{checksum="",path="caddy",version="(devel)"} 1
# HELP promhttp_metric_handler_requests_in_flight Current number of scrapes being served.
# TYPE promhttp_metric_handler_requests_in_flight gauge
promhttp_metric_handler_requests_in_flight 1
# HELP promhttp_metric_handler_requests_total Total number of scrapes by HTTP status code.
# TYPE promhttp_metric_handler_requests_total counter
promhttp_metric_handler_requests_total{code="200"} 0
promhttp_metric_handler_requests_total{code="500"} 0
promhttp_metric_handler_requests_total{code="503"} 0
@Mohammed90 Also, it’s not clear whether I need the global setting then?
suggested:
	metrics
:9000 {
  metrics /metrics
Is this the correct minimal?
:9000 {
  metrics /metrics
They’ll show up when you have traffic flowing.
They serve different purposes. The global option enables metrics collection and only exposes them on the admin endpoint (default: localhost:2019/metrics). The metrics handler which you add per-site allows you to expose metrics on a different endpoint in addition to the :2019/metrics. So, in this example:
You’ll be able to get metrics from both localhost:2019/metrics and :9000/metrics.
