Caddy v1.04
Ubuntu 18.04 - systemd
My complete Caddyfile or JSON config where “mydomain” is replaced with actual domain name and “my email” replaced with actual email address.
mydomain {
tls my email
timeouts none
proxy / 192.168.1.97:8096 {
websocket
# Optional security headers
header / {
-Server
Referrer-Policy "strict-origin"
X-Frame-Options "DENY"
# Optional logging
#log JellyfinProxy.log
For a little context, I am not in any way involved with networking, proxies, tls and so on. These terms are familiar but I am not sure my understanding is up to snuff. Likewise, if I brought a web designer, network admin or whatever to a turbine rebuild, you too would have difficulty with the terms we use daily in our trade, and your understanding may be not up to snuff. So please be patient ![]()
The caddyfile as posted has worked perfectly with no errors and I can reach my jellyfin server remotely. as I had intended. There is a permission issue with “log”, which is why it is commented out.
That said, I cannot figure out how to access my lan sites. My intention was for remote access to Jellyfin, which I was successful at achieving through web searches and trial and error. However, when I attempt to access site on my local lan, stored at /var/www/html/organizer, from another computer on the samelan I get the error “404 Site 192.168.1.97 is not served on this interface”
Numerous examples on numerous forums. Which probably work if I could see the full caddyfile, but generally they are snippets and I have no idea where to place these in my existing caddyfile, or if a separate caddyfile is required to be at /var/www/htm/.
For example;
If I place this snippet in my existing caddyfile
proxy / 192.168.1.97/ {
websocket
header_upstream Host {host}
header_upstream X-Forwarded-For {remote}
Will this do what I want, grant me access over lan to 192.168.1.97/Organizr?
If so, where exactly would I place this in my caddyfile?
I am putting together a new Caddyfile with the hope of acesss my lan, as well as remotely accessing stuff like nzbget using a snippet such as …
proxy /nzbget 127.0.0.1:6789 {
to access nzbget at https://mydomain/nzbget/
Assuming new Caddyfile will look like the following;
mydomain {
tls my@email.com
timeouts none
# Remote access to Jellyfin. ie mydomain
websocket
# Remote access to nzbget. ie mydomain/nzbget/
# Remote access to sonarr. ie mydomain/sonarr/
proxy /sonarr 127.0.0.1:8082 {
root /var/www/html/
websocket
header / {
-Server
# Optional logging
# log JellyfinProxy.log
This maybe so simple that I am missing it, or not, which is why I am here and asking for patience.
Thanks very much in advance for any help!"
