Migrating rewrite/redir from v1 to v2
This is a follow-on from this post. I’ve migrated from v1 to v2 except for this rewrite:
example.blog {
  redir /feed https://blog.example.com/feed.xml 301
  rewrite / {
    r ^/(\d+){3}/(.*)
    to {2}
   redir / https://search.example.com/search?query=site%3Ablog.example.com+{2}
The redir /feed works fine. It’s the rewrite which fails. The error from caddy v2 is:
run: adapting config using caddyfile: parsing caddyfile tokens for 'rewrite': Caddyfile:46 - Error during parsing: Wrong argument count or unexpected line ending after 'rewrite'
I’ve tried to do it in direct redir and uri but they both fail because I think it should parse the old html file name from the old /YYYY/MM/DD/blog-post.html uri structure. I’ve also tried rewrite * rather than rewrite /.
Suggestions? Pointers?
Thank you.
It works totally differently in v2.
First, read about request matchers:
In v1, matching was implemented differently for each directive. In v2, it’s now a generalized concept.
You need a path_regexp matcher for this.
@foo path_regexp foo ^/(\d+){3}/(.*)
rewrite @foo /{re.foo.2}
I just named the matcher and the regexp foo here, because I don’t know exactly the purpose of the rewrite, but I’m sure you can come up with something better.
Don’t forget to read the upgrade guide as well:
@francislavoie Thank you for the pointers. After more reading, here’s what works:
example.blog {
  @oldposts path_regexp oldpath ^/(\d+){4}/(\d+){2}/(\d+){2}/(.*)
  redir @oldposts https://search.example.com/search?query=site%3Ablog.example.com+{re.oldpath.4}
All 43 sites are now migrated to v2 in one Caddyfile. that redir/path_regexp was the final bit.
Thanks!
