1. Output of caddy version:
Docker
docker-compose up -d
version: "3.7"
image: caddy:2.4.6-alpine
- "8082:8082"
- /home/gitlab-runner/caddy/Caddyfile:/etc/caddy/Caddyfile
- /home/gitlab-runner/caddy/data:/data
- /home/gitlab-runner/caddy/config:/config
- developer
developer:
doc.adnet.hr {
reverse_proxy dockerhoster.adnet.local:1458
gitak.adnet.hr {
reverse_proxy https://gitak.adnet.local {
tls
tls_insecure_skip_verify
I want to move my letsencrypt handling from caddy (who reverse proxy-s to gitlab) directly to gitlab. But if I do it right away, caddy will be holding the reservation for the domain. That’s why caddy has to revoke the gitlab certificate, and then gitlab can take it from there. What’s the best way to revoke the certificate? Do I have to use certbot, or does caddy automatically revoke the certificates it doesn’t use? How fast will it revoke?
I tried to revoke the certificate by using certbot, but it got too complicated. There has to be an easier solution.
