Migrate to using a wildcard certificate
I’d just copy this line into your handle @udance as well.
Named matchers are ANDed together:
You can use the not matcher to essentially hack together a OR, kinda like this:
@phpmyadmin not {
    not expression `{phpmyadmin} == "yes"`
    not host udance.com.au
But that’s insane, don’t do it :joy:
Works like this basically:
>>> !(!true && !true)
=> true
>>> !(!true && !false)
=> true
>>> !(!false && !true)
=> true
>>> !(!false && !false)
=> false
Which as you can see is the same results as:
>>> true || true
=> true
>>> true || false
=> true
>>> false || true
=> true
>>> false || false
=> false
…and yet this appeared to be ORed (that’s what kinda threw me)?
Are you trying to do my head in? That’s like saying ‘Two wrongs don’t make a right, but three lefts do make a right’, which it does. Try it!
Unfortunately, that didn’t work. The map default switch takes precedence.
Unless I use map default to point to the domain udance.com.au, I realised, trying to implement the structure below can become quite complicated, resulting in a block that more difficult to follow and consequently more difficult to debug.
*.udance.com.au udance.com.au {
By keeping the domain+www and the subdomains in separate blocks, the complications and resulting issues can be avoided. If I accept that using map default to point to the domain is not best practice, the solution, for me, becomes:
udance.com.au www.udance.com.au {
  import tlsdns
  import logging udance
  import authproxy /phpmyadmin*
  reverse_proxy /tautulli* 10.1.1.26:8181
  reverse_proxy /transmission* 10.1.1.28:9091
  reverse_proxy 10.1.1.55
*.udance.com.au {
  import tlsdns
  import logging udance-wild
  map {labels.3} {upstream} {phpmyadmin} {
#   HOSTNAME     IPADDRESS       PHPMYADMIN
    # Docker containers
    office       10.1.1.17:80       no       # OnlyOffice
    portainer    10.1.1.13:9000     no       # Portainer
    truecommand  10.1.1.17:8080     no       # TrueCommand
    tc123        10.1.1.13:8080     no       # TrueCommand v1.2.3
    nc-fpm       10.1.1.13:8031     no       # Nextcloud+Caddy
    wordpress    10.1.1.13:5050     no       # WordPress
    nc-apache    10.1.1.13:8030     no       # Nextcloud+Apache
    collabora    10.1.1.17:9980     no       # Collabora
    # Jails
    rslsync      10.1.1.22:8888     no       # Resilio Sync
    cloud        10.1.1.29:80       no       # Nextcloud
    heimdall     10.1.1.23:80       no       # Heimdall
    blog         10.1.1.54:80       yes      # blog.udance.com.au
    test         10.1.1.50:80       yes      # test.udance.com.au
    basil        10.1.1.56:80       yes      # basil.udance.com.au
    sachika      10.1.1.57:80       yes      # sachika.udance.com.au
    default      unknown            no       # subdomain does not exist
# Error handling
  @unknown expression `{upstream} == "unknown"`
  handle @unknown {
    respond "Denied" 403
# Authenticate phpMyAdmin on production WordPress sites
  @phpmyadmin expression `{phpmyadmin} == "yes"`
  handle @phpmyadmin {
# Using the Nextcloud+Apache Docker image with Caddy.
  @nc-apache host nc-apache.udance.com.au
  handle @nc-apache {
    redir /.well-known/carddav /remote.php/carddav 301
    redir /.well-known/caldav /remote.php/caldav 301
  reverse_proxy {upstream}
Matchers of the same type are ORed together. The Caddyfile adapter merges them together if possible. But it’s complicated. The docs should be pretty clear about how each matcher behaves. In the named matcher section, it mentions:
Multiple matchers of the same type may be combined (e.g. multiple path matchers in the same set) using boolean algebra (AND/OR), as described in their respective sections below.
And the host matcher says:
Multiple host matchers will be OR’ed together.
I agree that’s much better :grin:
