Migrate Reverse Proxy for Grafana from Nginx Proxymanager to Caddy - Origin not allowed
Hi all,
I am new to caddy, but I am trying to migrate my external reverse proxy for grafana from nginx proxymanager to caddy.
There is also an internal reverse proxy (traefik) for grafana, so that I can not simply talk to grafana on port 3000, instead of this I have to use a name based hostname.
I can login when I switch the external reverse proxy to caddy, but I got error message from all panels “origin not allowed”
Docker-Compose
version: '3'
    image: caddy
      - "./data/container-config:/etc/caddy/:z"
      - "./data/site:/srv:z"
      - "./data/data:/data:z"
      - "./data/config:/config:z"
      - "./data/logs:/logs:z"
      - "/etc/localtime:/etc/localtime:ro"
grafana.external.com {
        reverse_proxy grafana.internal {
            header_up Host {http.reverse_proxy.upstream.host}
Getting this working with nginx I had to use something like that:
location / {
  proxy_set_header Host domainA;
  proxy_set_header Origin https://domainA;
  proxy_pass https://domainA;
But doing so with caddy (header_up Origin grafana.internal) I am getting a white page with “origin not allowed” and not only from the panels.
I think you need to include https:// in your Origin header in Caddy as well.
