job_noam
(Noam)
August 12, 2021, 10:47am
#1
Hi,
I’m trying to upgrade my Caddyfile from Caddy version 1 to version 2 (yes, I know it’s about time).
Anyway, this is my existing Caddyfile:
http:// {
header / Server "Engine"
proxy / 79.223.8.111 {
header_downstream -server
https:// {
ask https://www.myDomain.com
tls xxx@xxxx.com
First, it will be great if someone can save me some time and upgrade it to version 2. I already did it my self but it will be great if I did it right.
Second, I have a lot of domains under my Caddy servers and I don’t know to what I need to translate this lines:
“http:// {”
“https:// {”
I need it to answer to any domain I point to my servers automatically.
Thank!
Did you take a look at the upgrade guide?
What did you land on then? Please post what you actually tried.
That stays the same. You’re using Caddy’s On-Demand TLS feature. Read the docs to see how it works and how to configure it in Caddy v2:
job_noam
(Noam)
August 12, 2021, 7:49pm
#3
I tried this (https://) and it’s not working:
(Only when I put a domain name instead of https:// it’s working)
https:// {
reverse_proxy 77.223.8.111 {
header_down -server
header_down -proxy-cache
header_down -proxy-cache-tag
You need to tell Caddy how to manage certificates. In Caddy v1, you used On-Demand TLS. This means that you’ll also need to enable On-Demand TLS in Caddy v2. Read the docs I linked for that.
job_noam
(Noam)
August 13, 2021, 1:00am
#5
OK, now everything is working great. Thx
system
(system)
closed
September 11, 2021, 10:47am
#6
