Miguel_L
(Miguel L.)
1
Hi
I have a problem for publish /metrics in a overlaynetwork.
my Caddyfile contains:
{ admin :2019 }
but i test other combinations like
{ admin :0.0.0.0:2019 }
:2019 {metrics }
I see that in the logs:
INF ts=1730934640.2747128 logger=admin msg=admin endpoint started address=localhost:2019 enforce_origin=false origins=["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]
with wget i achieve get /metrics with 127.0.0.1:2019/metrics, but with ip address of the network I find refused connection
maybe is for the docker swarm plugin for docker?
Miguel_L
(Miguel L.)
2
Finnally was a problem with the plugin, I found the solution in the github of the plugin.
Me mistake, sorry
What plugin? Please explain.
Miguel_L
(Miguel L.)
4
Sorry
This plugin:
lucaslorentz/caddy-docker-proxy: Caddy as a reverse proxy for Docker
great plugin for automate connect stack an services in docker swarm, to caddy
And what was the problem? That’s the whole point. Don’t just say “there was a problem”.
system
(system)
Closed
6
