On the reverse proxy:
On the caddy web server
Caddy Reverse proxy in the cloud, and Caddy on the backend
Debian 9
sudo systemctl start caddy
N/A
Caddy Reverse Proxy: (floatboat.ninja)
floatboat.ninja
# Set server header
Server "Apache"
# enable HSTS
Strict-Transport-Security "max-age=31536000"
# clickjacking protection
X-Frame-Options DENY
reverse_proxy vpc1029.mkz.com:5656 {
header_down X-Real-IP {http.request.remote}
level DEBUG
output file /var/log/access.log {
roll_size 1gb
roll_keep 5
roll_keep_for 720h
Caddy Webserver (vpc1029.mkz.com):
:5656 {
root * c:\users\caddy\documents\caddyroot
-Server
-X-Content-Type-Options
level DEBUG
output file c:\users\caddy\documents\access.log {
roll_size 1gb
roll_keep 5
roll_keep_for 720h
handle_errors {
@404 {
expression {http.error.status_code} == 404
templates
respond @404 "404"
I’m trying to get the real IP address of the connecting client from a reverse proxy so that I can return it in the respond of the handle_errors section on the caddy webserver. When I use {remote}, it’s returning the IP address of the proxy server, not the originating client (which is expected). I’ve looked for a way of passing over the IP address in the reverse proxy and while it works, I’m not sure if there’s a directive / template that I can then use that will allow me to specify the custom header and return it in the 404 directive. i.e.
handle_errors {
@404 {
templates
respond @404 "{header.X-Real-IP}"
None
I’ve tried to use {http.request.remote.host} {remote} but they both return the proxy ip address, not the client’s ip.
N/A
