Hi there,
i would use the TyperCaddy Reverse Proxy Server (Caddy Proxy GUI) to proxy the Audio/Video Streams.
We have installed it successful. We have the following issues:
We have add a test Proxy Server: http://prntscr.com/nzlfay
And also add following Host: http://prntscr.com/nzlfky
Our test domain: [h t t p://proxytv.xxxxxxx.tv:25461](h t t p://proxytv.xxxxxxx.tv:25461/) does successfully redirects to our streaming main server: http://
and it does also does open the Playlist from there. But the Playlist does contain the IP Adress as streaming links like:
h t t p://xxx.xxx.xxx.xxx:25461/proxyuser/proxypass/15755
instead of the Domain:
h t t p://proxytv.xxxxxxx.tv:25461/proxyuser/proxypass/15755
If I redirect the Domain directly to the Main Server IP (without using the Proxy) and download the Playlist, so, in this case, the Playlist contains the correct streaming link, like:
Very important is also,
If i try to open the direct stream url, so i can play the stream via VLC.
If the link is direct by the proxy, so VLC can’t open the stream.
So basically, are there some special or custom configurations on the proxy settings to redirect also video streams?
Our target is to protect the IP of our Mainserver.
Thanks and regards.
Update:
The Option “Transparent” solve the issue with getting the correct epoxying streaming links like:
But the streams still not open even though the source Link is correct.
Just for basic info, if I open the Link on a Browser without using the proxy, I get a download file with type: video/mp2t ( http://prntscr.com/o0b36x )
I just read also the caddyserver wiki and community, i have there something with the MIME Types and Header Settings, but i am very new and i don’t know about those settings.
I just see here: http://prntscr.com/o0b1cc some configuration options, but i don’t know about their possible values and settings.
Maybe someone can help me out, to set the correct values for the type: video/mp2t and all other Media MIME Types
Thanks an regrads
