So I switched to Caddy recently from nginx and I love it. However I have one concern I cannot figure out.
I want to basicauth for a specific area UNLESS it is within the /api/ path. However, I can’t seem to get caddy to accept this.
One section that works no problem is this…
import tlscf
basicauth /abc/UI* {
{$XAUTH}
reverse_proxy abc:9117 {
import proxyheaders
To adapt this to my first mentioned question, I tried this…
https://abcd.dulanic.com {
import tlscf
basicauth not path /api/* {
{$XAUTH}
reverse_proxy demo:8088 {
header_up X-Forwarded-Host {host}:8088
header_up -Origin
header_up -Referer
However, this errors out /w Wrong argument count or unexpected line ending after ‘/api/*’
It looks like this should work as that is a direct example at Request matchers (Caddyfile) — Caddy Documentation but I am sure I am misunderstanding how not works for this. Since /api/ is a subfolder of / I can’t define what I want to have basicauth, I need to define what I do not want.
I also tried without path as the first method worked without path, and that didn’t help.
