Manual issuance from internal PKI?
2.5.1 from apt
Stock systemd unit on Ubuntu 22.04.
        servers :443 {
                protocol {
                        experimental_http3
                        #strict_sni_host
        email ...
        pki {
                ca {
                        name "Quake CA"
localhost:2020, Quake:2020 {
        tls internal
        acme_server
        file_server /var/www/acme
No problem, actually. I was just trying to use the internal CA, either via acme or not, to issue certificates for containers I want to reverse proxy.
I tried looking pretty much anywhere to see if I can disable validation in the acme server, like it were pebble, or if there’s a command somewhere to issue a certificate manually from the intermediates Caddy produces, but I am not sure I want to go that route with openssl and its CLI.
We don’t currently have a way to do it directly, but we’ll likely add it eventually, as an admin API endpoint that takes basically a CSR (certificate signing request) and gives you back a cert.
If you want to use ACME then yeah, use the acme_server directive and point your ACME client to Caddy.
It’s not that I want to use it. I just explored using it to get a certificate. But I would have to also point the acme server to a fake resolver that always answers “yeah, that’s 127.0.0.1” for every possible query :smiley:
You can run CoreDNS:
https://coredns.io/
Sounds fun
