"malformed HTTP response" when proxying WebSockets to Heroku
I am trying to proxy our site through Caddy to Heroku. Long-term we want to migrate to other provider.
While HTTP(S) proxying works fine, I have issues with WSS/WebSockets.
When we are running
wscat -c wss://our.staging.host/cable
It hangs for slightly under 6 minutes and in Caddy logs I can see logs pasted in next section.
    "duration": 352.062551103,
    "err_id": "x7zksa8bt",
    "err_trace": "reverseproxy.statusError (reverseproxy.go:1299)",
    "level": "error",
    "logger": "http.log.error",
    "msg": "net/http: HTTP/1.x transport connection broken: malformed HTTP response \"\\x15\\x00\\x00\\x00\\x02\\x01\\x00\"",
    "request":
        "headers":
            "Connection":
                "Upgrade"
            "Upgrade":
                "websocket"
        "host": "our.staging.host",
        "method": "GET",
        "proto": "HTTP/1.1",
        "remote_ip": "10.31.12.1",
        "remote_port": "58020",
        "tls":
            "cipher_suite": 4865,
            "proto": "",
            "resumed": false,
            "server_name": "our.staging.host",
            "version": 772
        "uri": "/cable"
    "status": 502,
    "ts": 1686306304.828851
and
    "level": "error",
    "logger": "http.log.access",
    "msg": "handled request",
    "request":
        "headers":
        "method": "GET",
        "tls":
            "proto": "",
            "resumed": false,
            "version": 772
        "uri": "/cable"
    "resp_headers":
        "Server":
            "Caddy"
    "size": 0,
    "status": 502,
    "ts": 1686306304.82889,
    "user_id": ""
EKS 1.26, ARM, custom Helm chart
/usr/bin/caddy run --config /etc/caddy/config/content --adapter caddyfile
not relevant I guess(?)
(server_defaults) {
  metrics
  protocols h1 h2
  acme_ca https://acme.zerossl.com/v2/DV90
  acme_eab {
    key_id  {$EAB_KEY_ID}
    mac_key {$EAB_HMAC_KEY}
  admin 0.0.0.0:2019
  grace_period 10s
    output stdout
    format filter {
      wrap json
  on_demand_tls {
    ask http://caddy-ask-api.default/internal/account_domain_validation/{$API_TOKEN}
    burst    10
    interval 1s
  servers {
    import server_defaults
  servers :80 {
    name http
  servers :443 {
    name https
  shutdown_delay 10s
  storage dynamodb caddy-staging-table
# We use it only for probes, we do not log anything here
internal:80 {
  @goingDown vars {http.shutting_down} true
  respond @goingDown "Bye-bye in {http.time_until_shutdown}" 503
  respond "OK!"
:80, :443 {
  log
  @websockets {
    header Connection *Upgrade*
    header Upgrade    websocket
  reverse_proxy @websockets wss://our-staging.herokuapp.com:443 {
  reverse_proxy https://our-staging.herokuapp.com {
  tls "caddy@our.domain.io" {
    on_demand
It behaves the same if I drop wss:// from the reverse proxy. When I switch to https://, I am getting 404 from Heroku.
wss:// is not a valid scheme for Caddy’s proxy. See the docs which explain: reverse_proxy (Caddyfile directive) — Caddy Documentation. Because it’s not valid, it’s the same as the default which is HTTP.
In fact, you don’t need that reverse_proxy at all, it’s a duplicate of your other one with https://. You don’t need the websockets matcher in this case because you’re proxying both websocket and HTTP traffic to the same place. A matcher is only needed if you need to split the traffic (i.e. websockets proxied to one place, HTTP to another).
I can’t answer why the 404 happens, that’s a problem with your upstream that you need to figure out.
Thanks for clarification! I thought it is an upstream issue, but wasn’t sure. Heroku support is sometimes hard to talk to.
If someone comes here with similar issue. In our case, it was due to the Rails’ request_forgery_protection implementation. It only checks Host header, where it should consider X-Forwarded-* when available. At least other web servers/frameworks do it.
