I am trying to setup a mailu server. I get a blank caddy connection when connecting to the reverse proxy route. I have changed maliu’s front containers ports and it’s tls is set to the setting recommended for reverse proxying
Did a pastebin cause the logs are large.
v2.8.4
systemctl start caddy
# caddy.service
# for your installation.
Description=Caddy web server
After=network-online.target
Wants=network-online.target
StartLimitIntervalSec=14400
StartLimitBurst=10
Type=notify
Environment=XDG_DATA_HOME=/var/lib
Environment=XDG_CONFIG_HOME=/etc
ExecStartPre=/usr/bin/caddy validate --config /etc/caddy/Caddyfile
ExecStopPost=/usr/bin/rm -f /run/caddy/admin.socket
# Do not allow the process to be restarted in a tight loop. If the
# process fails to start, something critical needs to be fixed.
Restart=on-abnormal
# Use graceful shutdown with a reasonable timeout
# Hardening options
DevicePolicy=closed
LockPersonality=true
MemoryAccounting=true
MemoryDenyWriteExecute=true
NoNewPrivileges=true
PrivateDevices=true
ProcSubset=pid
ProtectClock=true
ProtectControlGroups=true
ProtectHome=true
ProtectHostname=true
ProtectKernelLogs=true
ProtectKernelModules=true
ProtectKernelTunables=true
ProtectProc=invisible
ProtectSystem=strict
RemoveIPC=true
ReadWritePaths=/var/lib/caddy /var/log/caddy /run/caddy
RestrictNamespaces=true
RestrictRealtime=true
RestrictSUIDSGID=true
# The configuration below serves a welcome page over HTTP on port 80.
# domain name.
# https://caddyserver.com/docs/caddyfile/concepts#addresses
# Restrict the admin interface to a local unix file socket whose directory
# is restricted to caddy:caddy. By default the TCP socket allows arbitrary
# modification for any process and user that has access to the loc
https://admin.tizwarp.dev {
reverse_proxy localhost:9090 {
tls_insecure_skip_verify
https://vault.tizwarp.dev {
reverse_proxy 192.168.1.107:8030
https://mail.aberrant.works {
reverse_proxy 192.168.1.107:7443
# Import additional caddy confg files in /etc/caddy/conf.d/
