Lots of errors pouring into the log file that seem to be harmless. The site is working fine.
Not sure what I am doing wrong to get all these errors? The logs get quite large after a day or so…
Ubuntu 20.04.3 LTS (aka focal)
systemd 245 (245.4-4ubuntu3.14)
Running on a DigitalOcean droplet
INBOUND:
ICMP
HTTP (80)
HTTPS (443)
OUTBOUND:
ICMP
TCP (all ports)
UDP (all ports)
sudo cp myCaddyfile /etc/caddy/Caddyfile
sudo systemctl reload caddy.service
caddy.service
# caddy.service
# for your installation.
Type=notify
Caddyfile
# domain name.
# :80
# root * /usr/share/caddy
# file_server
# reverse_proxy localhost:3000
# php_fastcgi localhost:9000
http://meris.xyz {
redir https://www.meris.xyz{uri} permanent
(meris_rproxy) {
reverse_proxy {
to 0.0.0.0:{srv_port}
header_up ext-host {meris_host}
header_up host {host}
header_up origin {origin}
# handle direct DNS queries
www.meris.xyz {
# send all ddp requests to shared server @admin.test.meris.xyz
map {host} {meris_port} {srv_port} {meris_host} {
# "stest.meris.xyz" 5880 4880 "stest.meris.xyz"
# "stage.meris.xyz" 5280 4280 "stage.meris.xyz"
"www.meris.xyz" 5080 4080 "www.meris.xyz"
import meris_rproxy
# all queries logged to stderr by default
# ADMIN Routing
admin.meris.xyz {
map {host} {srv_port} {meris_host} {
# "admin.stest.meris.xyz" 5880 "admin.stest.meris.xyz"
# "admin.stage.meris.xyz" 5280 "admin.stage.meris.xyz"
"admin.meris.xyz" 5080 "admin.meris.xyz"
import meris_rproxy
# MINIO
https://b.meris.xyz, https://blob.meris.xyz {
reverse_proxy {
to 0.0.0.0:9000
header_up Host {host}
health_uri /minio/health/ready
tls.issuance.acme is pouring out errors.
Many of the errors are for domains not listed in my Caddyfile except within comments and one domain is not in the file at all.
Here is a sampling of them:
Error samples
# this looks right
Jan 4 21:26:13 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"info","ts":1641349573.679473,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["b.meris.xyz","blob.meris.xyz","www.meris.xyz","admin.meris.xyz"]}
# only used as http://
Jan 4 21:26:32 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349592.0677156,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"meris.xyz","error":"no information found to solve challenge for identifier: meris.xyz"}
# OK these should be challenged
Jan 4 21:26:34 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349594.1415145,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"www.meris.xyz","error":"no information found to solve challenge for identifier: www.meris.xyz"}
Jan 4 21:26:39 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349599.2948058,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"admin.meris.xyz","error":"no information found to solve challenge for identifier: admin.meris.xyz"}
Jan 4 21:26:34 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349594.106386,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"b.meris.xyz","error":"no information found to solve challenge for identifier: b.meris.xyz"}
# whoa! These domains are mentioned behind comments
# whey are they being challenged?
Jan 4 21:26:32 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349592.856338,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"admin.stest.meris.xyz","error":"no information found to solve challenge for identifier: admin.stest.meris.xyz"}
Jan 4 21:26:39 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349599.3018298,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"admin.stage.meris.xyz","error":"no information found to solve challenge for identifier: admin.stage.meris.xyz"}
Jan 4 21:26:42 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349602.25449,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"stest.meris.xyz","error":"no information found to solve challenge for identifier: stest.meris.xyz"}
Jan 4 21:26:47 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349607.1742175,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"stage.meris.xyz","error":"no information found to solve challenge for identifier: stage.meris.xyz"}
# whoa! whoa! this domain is not even in my Caddyfile
# I had it in previous Caddyfiles but have since
# reloaded and then I stopped the service and restarted
# then I rebooted. This old name is still haning around
Jan 4 21:26:34 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349594.112324,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"bconsole.meris.xyz","error":"no information found to solve challenge for identifier: bconsole.meris.xyz"}
Note: tried to use debug directive but it failed
Jan 4 21:22:04 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1771]: reload: adapting config using caddyfile: /etc/caddy/Caddyfile:45: unrecognized directive: debug
5 minutes of logs
Jan 4 21:26:13 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1978]: {"level":"info","ts":1641349573.6682084,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Jan 4 21:26:13 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1978]: 2022/01/04 21:26:13 [WARNING] Unnecessary header_up ('X-Forwarded-Proto' field): the reverse proxy's default behavior is to pass headers to the upstream
Jan 4 21:26:13 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1978]: {"level":"warn","ts":1641349573.672293,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":27}
Jan 4 21:26:13 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"info","ts":1641349573.6735933,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_addr":"127.0.0.1:43844","headers":{"Accept-Encoding":["gzip"],"Content-Length":["1913"],"Content-Type":["application/json"],"Origin":["localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
Jan 4 21:26:13 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"info","ts":1641349573.676234,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
Jan 4 21:26:13 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"info","ts":1641349573.6768236,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Jan 4 21:26:13 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"info","ts":1641349573.6771376,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Jan 4 21:26:13 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"info","ts":1641349573.6773958,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv1","http_port":80}
Jan 4 21:26:13 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"info","ts":1641349573.6845386,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0000f4a10"}
Jan 4 21:26:13 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"info","ts":1641349573.6854987,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0000f4540"}
Jan 4 21:26:13 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"info","ts":1641349573.6865418,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Jan 4 21:26:13 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"info","ts":1641349573.6879818,"logger":"admin.api","msg":"load complete"}
Jan 4 21:26:13 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"info","ts":1641349573.6998959,"logger":"admin","msg":"stopped previous server","address":"tcp/localhost:2019"}
Jan 4 21:26:32 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349592.0679114,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"meris.xyz","error":"no information found to solve challenge for identifier: meris.xyz"}
Jan 4 21:26:32 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349592.856437,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"admin.stest.meris.xyz","error":"no information found to solve challenge for identifier: admin.stest.meris.xyz"}
Jan 4 21:26:34 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349594.1062756,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"b.meris.xyz","error":"no information found to solve challenge for identifier: b.meris.xyz"}
Jan 4 21:26:34 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349594.1129026,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"bconsole.meris.xyz","error":"no information found to solve challenge for identifier: bconsole.meris.xyz"}
Jan 4 21:26:34 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349594.1345665,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"b.meris.xyz","error":"no information found to solve challenge for identifier: b.meris.xyz"}
Jan 4 21:26:34 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349594.1351318,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"b.meris.xyz","error":"no information found to solve challenge for identifier: b.meris.xyz"}
Jan 4 21:26:34 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349594.142327,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"www.meris.xyz","error":"no information found to solve challenge for identifier: www.meris.xyz"}
Jan 4 21:26:34 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349594.1703396,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"www.meris.xyz","error":"no information found to solve challenge for identifier: www.meris.xyz"}
Jan 4 21:26:34 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349594.1708992,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"www.meris.xyz","error":"no information found to solve challenge for identifier: www.meris.xyz"}
Jan 4 21:26:39 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349599.2640316,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"admin.meris.xyz","error":"no information found to solve challenge for identifier: admin.meris.xyz"}
Jan 4 21:26:39 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349599.2641172,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"admin.meris.xyz","error":"no information found to solve challenge for identifier: admin.meris.xyz"}
Jan 4 21:26:39 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349599.2942057,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"admin.meris.xyz","error":"no information found to solve challenge for identifier: admin.meris.xyz"}
Jan 4 21:26:39 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349599.3019164,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"admin.stage.meris.xyz","error":"no information found to solve challenge for identifier: admin.stage.meris.xyz"}
Jan 4 21:26:40 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349600.1123993,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"meris.xyz","error":"no information found to solve challenge for identifier: meris.xyz"}
Jan 4 21:26:40 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349600.1124938,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"meris.xyz","error":"no information found to solve challenge for identifier: meris.xyz"}
Jan 4 21:26:42 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349602.254576,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"stest.meris.xyz","error":"no information found to solve challenge for identifier: stest.meris.xyz"}
Jan 4 21:26:47 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349607.1740549,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"stage.meris.xyz","error":"no information found to solve challenge for identifier: stage.meris.xyz"}
Jan 4 21:27:35 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349655.8039985,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"meris.xyz","error":"no information found to solve challenge for identifier: meris.xyz"}
Jan 4 21:27:35 ubuntu-s-1vcpu-1gb-amd-nyc1-01 caddy[1369]: {"level":"error","ts":1641349655.8041055,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"meris.xyz","error":"no information found to solve challenge for identifier: meris.xyz"}
- Trimmed down the Caddyfile to its basics. I have been trying to reuse a single Caddyfile so I got rid of all of the unused stuff for this server.
- In addition to executing the
systemctl reload caddy.serviceI have tried
systemctl stop caddy.service
systemctl start caddy.service
Finally tried:
sudo reboot
I still keep getting the errors
