1. Output of caddy version
CentOS7
systemctl start caddy
Type=notify
(handle_info_log) {
output file /var/log/caddy/info.log {
roll_size 100MiB
roll_keep_for 30d
#roll_local_time
format console {
time_format wall
time_local
level INFO
(handle_error_log) {
output file /var/log/caddy/error.log {
roll_size 30MiB
roll_keep_for 30d
#roll_local_time
format console {
time_format wall
time_local
level ERROR
(handle_errors) {
handle_errors {
rewrite * /{err.status_code}.html
www.tigerice.cn {
import handle_errors
import handle_info_log
import handle_error_log
handle_path /merchant/* {
root * /opt/twomicro_v2/web/merchant
handle_path /torna/* {
root * /opt/twomicro_v2/web/torna
handle_path /dingding/* {
root * /opt/twomicro_v2/web/dingding
handle_path /formmaking/* {
root * /opt/twomicro_v2/web/dist
@nacos path /nacos*
reverse_proxy @nacos {
header_down Access-Control-Allow-Origin *
header_down Access-Control-Allow-Methods GET,POST,OPTIONS
header_down Access-Control-Allow-Headers X-Requested-With
to http://127.0.0.1:8848
reverse_proxy /demo-framework/* {
to localhost:8081
reverse_proxy /demo-example/* {
to localhost:8081
Login to the web system succeeded, but logout failed. HTTP status 404.
curl -v https://www.tigerice.cn/merchant/user/login?redirect=%2Ftorna%2F
* About to connect() to www.tigerice.cn port 443 (#0)
* Trying 43.143.173.96...
* Connected to www.tigerice.cn (43.143.173.96) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* SSL connection using TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
* subject: CN=www.tigerice.cn
* start date: Nov 17 11:33:09 2022 GMT
* expire date: Feb 15 11:33:08 2023 GMT
* common name: www.tigerice.cn
* issuer: CN=R3,O=Let's Encrypt,C=US
> GET /merchant/user/login?redirect=%2Ftorna%2F HTTP/1.1
> User-Agent: curl/7.29.0
> Host: www.tigerice.cn
< HTTP/1.1 404 Not Found
< Alt-Svc: h3=":443"; ma=2592000
< Server: Caddy
< Date: Fri, 25 Nov 2022 08:14:01 GMT
< Content-Length: 0
* Connection #0 to host www.tigerice.cn left intact
CApath: none
> GET /merchant/user/lo HTTP/1.1
< Server: Caddy
< Date: Fri, 25 Nov 2022 08:14:06 GMT
< Content-Length: 0
First , i fixed regular expression, but the directive handle_path can only math /merchant* or /merchant/*, i will try handle
