ubuntu 18.04
https://example.net, example.net {
root * /var/www/rtl.example.net/current/public
#log /var/log/caddy/access.log
#errors /var/log/caddy/error.log
#gzip
#browse
# Add trailing slash for directory requests
@canonicalPath {
file {
try_files {path}/index.php
not path */
redir @canonicalPath {path}/ 308
# If the requested file does not exist, try index files
@indexFiles {
file {
try_files {path} {path}/index.php index.php
split_path .php
rewrite @indexFiles {http.matchers.file.relative}
# Proxy PHP files to the FastCGI responder
@phpFiles {
path *.php
reverse_proxy @phpFiles unix:/run/php/php7.3-fpm.sock {
transport fastcgi {
split .php
nothing gets logged to the /var/log/caddy/access.log
What i’m trying to do is get error logs. But not found any useful examples in the docs on how to do this. I read the pages on logging. But other than options for logging and customization there is nothing on how to turn it on or use it.
read the logging docs
