1. Caddy version:
Debian install of Caddy via Caddy’s repo, update-alternatives
method used to swap over to xcaddy build with caddy-dns/cloudflare
, caddyserver/transform-encoder
and gamalan/caddy-tlsredis
systemctl start caddy-api
Standard provided by repo, with the following modifications via systemctl edit caddy-api
# /etc/systemd/system/caddy-api.service.d/override.conf
ExecStart=
ExecStart=/usr/bin/caddy run --environ --resume --config /etc/caddy/Caddyfile
EnvironmentFile=/etc/caddy/envfile.env
#debug
admin 0.0.0.0:2019
default_sni {env.CADDY_SVR_PUB_FQDN}
email certadmin@boldcity.tech
acme_dns cloudflare {env.CADDY_CF_API_TOKEN}
(logging_json) {
level INFO
output file /srv/data-log/caddy/json/{vars.loghost}.json {
roll_size 10MB
roll_keep 10
format console
(logging_combinedvhost) {
output file /srv/data-log/caddy/clf/{vars.loghost}.log {
roll_size 10MB
roll_keep 30
# Apache Combined Log Format, modified to include the vhost as the first 'column'; standard name is 'combinedv'.
# TODO: Fix combinedv request port; We add the request's host correctly but fake the port, as I haven't yet figured out how to get the real port number
format transform `{request>host}:443 {request>remote_ip} - {request>user_id} [{ts}] "{request>method} {request>uri} {request>proto}" {status} {size} "{request>headers>Referer>[0]}" "{request>headers>User-Agent>[0]}"` {
time_format "02/Jan/2006:15:04:05 -0700"
(conf_proxy_up_headers) {
# Tell the upstream backend server what Frontend proxied the request
header_up x-feserver-ip {env.CADDY_SVR_INT_IP}
header_up X-feserver {env.CADDY_SVR_INT_HOSTNAME}
# TODO: Remove legacy X-Forwarded-By once all backends are migrated to new header field.
header_up X-Forwarded-By {env.CADDY_SVR_INT_HOSTNAME}
# The the upstream backend server the real source IP of the request.
# Caddy automatically adds the following headers: X-Forwarded-Proto, X-Forwarded-Host, X-Forwarded-For
# Remove the 'Server' header from the upstream server's response
header_down -Server
(conf_headers_standard) {
# Tell the client browser the (public) name of the frontend server
header x-feserver {env.CADDY_SVR_PUB_HOSTNAME}
(test-1.potts.in) {
reverse_proxy {
to http://upstream-test:81
flush_interval -1
import conf_proxy_up_headers
test-1.potts.in:80 {
vars loghost "test-1.potts.in"
import logging_json
import logging_combinedvhost
import conf_headers_standard
import test-1.potts.in
d. Simplified Caddy config
This is a simplified version of the above config for testing (and easier human parsing)
level INFO
format console
root * /usr/share/caddy
I have two problems/goals:
1: Log twice
To help ease my migration from the legacy Apache CombinedV log format, I would like to log to both the Caddy json format AND combinedv.
If I have both snippets included, the last one in the config wins.
I know there are ways to convert the json format to combinedv but my current logging workflow (GoAccess & fail2ban, among other things) likes to read the file realtime.
Is it possible to log twice?
2: Variable in log’s file name
As I have a bunch of sites and I love simplifying things, I am taking full advantage of snippets. The top config shows what I am doing, but since I want to have different log files for each site, I can’t easily use snippets as I need to customize the log’s file name for each site.
If I try to set a variable to the filename I want, caddy adapt
works fine but the resulting json config throws an error.
{"error":"loading new config: setting up custom log 'log0': loading log writer module: loading module 'file': provision caddy.logging.writers.file: invalid filename for log file: unrecognized placeholder {http.vars.loghost}"}
What’s the best way to dynamically change the filename of the log file when referenced in a site block?
Is it possible to put a variable in the filename somehow or perhaps another method?
Is there a pre-defined variable in the context of a site block that contains the site’s address?
Thanks so much!
