Logging configuration is not applied after reloading Caddy
I use the default Caddy configuration and add logging:
        root * /usr/share/caddy
                roll_size 2MiB
                roll_keep 5
If I change the roll_size and roll_keep parameters, their new values are only applied after I restart Caddy, but are not applied after I reload it.
I tested this behavior for version 2.9.1 and 2.10.0
Is this expected?
vagrant@vagrant:~$ caddy version
vagrant@vagrant:~$ curl -s http://localhost:2019/config/ | jq .logging.logs.log0.writer
  "filename": "/var/log/caddy/access.log",
  "output": "file",
  "roll_keep": 5,
  "roll_size_mb": 2
vagrant@vagrant:~$ ls -l /var/log/caddy
total 0
-rw------- 1 caddy caddy 0 Apr 28 10:05 access.log
vagrant@vagrant:~$ ab -n 20000 http://localhost/ &> /dev/null
total 2180
-rw------- 1 caddy caddy   54019 Apr 28 10:05 access-2025-04-28T10-05-50.389.log.gz
-rw------- 1 caddy caddy   54080 Apr 28 10:05 access-2025-04-28T10-05-50.683.log.gz
-rw------- 1 caddy caddy   54020 Apr 28 10:05 access-2025-04-28T10-05-50.973.log.gz
-rw------- 1 caddy caddy   53951 Apr 28 10:05 access-2025-04-28T10-05-51.260.log.gz
-rw------- 1 caddy caddy   53789 Apr 28 10:05 access-2025-04-28T10-05-51.548.log.gz
-rw------- 1 caddy caddy 1945134 Apr 28 10:05 access.log
vagrant@vagrant:~$ # updating roll_keep=10 and roll_size_mb=1MiB in /etc/caddy/Caddyfile
vagrant@vagrant:~$ sudo systemctl reload caddy
  "output": "file",
  "roll_keep": 10,
  "roll_size_mb": 1
total 2032
-rw------- 1 caddy caddy   53888 Apr 28 10:06 access-2025-04-28T10-06-32.504.log.gz
-rw------- 1 caddy caddy   54073 Apr 28 10:06 access-2025-04-28T10-06-32.799.log.gz
-rw------- 1 caddy caddy   53887 Apr 28 10:06 access-2025-04-28T10-06-33.084.log.gz
-rw------- 1 caddy caddy   54054 Apr 28 10:06 access-2025-04-28T10-06-33.374.log.gz
-rw------- 1 caddy caddy   53842 Apr 28 10:06 access-2025-04-28T10-06-33.666.log.gz
-rw------- 1 caddy caddy 1793477 Apr 28 10:06 access.log
vagrant@vagrant:~$ sudo systemctl restart caddy
total 1156
-rw------- 1 caddy caddy  27468 Apr 28 10:06 access-2025-04-28T10-06-49.374.log.gz
-rw------- 1 caddy caddy  27258 Apr 28 10:06 access-2025-04-28T10-06-49.522.log.gz
-rw------- 1 caddy caddy  27513 Apr 28 10:06 access-2025-04-28T10-06-49.679.log.gz
-rw------- 1 caddy caddy  27431 Apr 28 10:06 access-2025-04-28T10-06-49.826.log.gz
-rw------- 1 caddy caddy  27406 Apr 28 10:06 access-2025-04-28T10-06-49.971.log.gz
-rw------- 1 caddy caddy  27225 Apr 28 10:06 access-2025-04-28T10-06-50.113.log.gz
-rw------- 1 caddy caddy  27335 Apr 28 10:06 access-2025-04-28T10-06-50.257.log.gz
-rw------- 1 caddy caddy  27562 Apr 28 10:06 access-2025-04-28T10-06-50.427.log.gz
-rw------- 1 caddy caddy  27354 Apr 28 10:06 access-2025-04-28T10-06-50.571.log.gz
-rw------- 1 caddy caddy  27253 Apr 28 10:06 access-2025-04-28T10-06-50.711.log.gz
-rw------- 1 caddy caddy 896731 Apr 28 10:06 access.log
I installed Caddy using the official method for Ubuntu.
Ubuntu 24.04.2 LTS
Default caddy.service
See above
