Log { except <path> } directive in v2?
v2.2.0-rc.1-8-g744d04c2
caddy run --config ./Caddyfile.json
Raspbian 8.0 (Jessie)
shellinabox running on port 8080
see above
not applicable here
	"logging": {
		"logs": {
			"default": {
				"exclude": [
					"http.log.access.log0"
			"log0": {
				"writer": {
					"filename": "./www/access.txt",
					"output": "file"
				"encoder": {
					"field": "common_log",
					"format": "single_field"
				"include": [
	"apps": {
		"http": {
			"servers": {
				"srv0": {
					"listen": [
						":443"
					"routes": [
							"match": [
									"host": [
										"192.168.43.223"
							"handle": [
									"handler": "subroute",
									"routes": [
											"handle": [
													"handler": "vars",
													"root": "/home/pi/www"
													"encodings": {
														"gzip": {},
														"zstd": {}
													"handler": "encode"
											"handle": [
													"handler": "reverse_proxy",
													"upstreams": [
															"dial": "localhost:8080"
											"match": [
													"path": [
														"/shell/*"
							"terminal": true
					"logs": {
						"logger_names": {
							"192.168.43.223": "log0"
						"skip_hosts": ["192.168.43.223/shell/"]
		"tls": {
			"automation": {
				"policies": [
						"subjects": [
							"192.168.43.223"
						"issuer": {
							"module": "internal"
Caddy and shellinabox work just fine but I’d prefer not to have a log entry upon every keypress in the [shellinabox] shell. I had been able to avoid that with the “except <path>” Caddyfile directive in v1:
log / access.txt {
 except /shell
192.168.43.195 - - [30/Aug/2020:18:11:34 +0200] “POST /shell/? HTTP/2.0” 200 46
192.168.43.195 - - [30/Aug/2020:18:11:34 +0200] “POST /shell/? HTTP/2.0” 200 56
192.168.43.195 - - [30/Aug/2020:18:11:46 +0200] “POST /shell/? HTTP/2.0” 200 327
192.168.43.195 - - [30/Aug/2020:18:11:47 +0200] “POST /shell/? HTTP/2.0” 200 327
192.168.43.195 - - [30/Aug/2020:18:11:47 +0200] “POST /shell/? HTTP/2.0” 200 47
above “skip_hosts” statement in different variants in the JSON config.
(it does work for the “plain” host - but I am looking for a way to filter access to the /shell path only… )
Fudging, but works for me:
In modules/logging/encoders.go, appended
			if (strings.Contains(buf.String(), "/shell/?")) {
				buf.Reset()
in EncodeEntry before return.
Can close this
You could write a log writer plugin which can be configured to ignore certain kinds of logs
