Location matching for catch-all redirect
v2.2.0-rc.3
systemd on Ubuntu 18.04 (No docker)
# caddy.service
# for your installation.
After=network.target
  email <redacted>
  default_sni get.geojs.io
http://*.geojs.io {
  respond /check 200
  redir https://{host}{uri}
https://*.geojs.io {
  reverse_proxy 127.0.0.1:8080
  encode zstd gzip
  # Do not log!
    output discard
    dns cloudflare <redacted>
I have a requirement to respond to a HTTP request that comes in over HTTP (not HTTPS!) but otherwise want to redirect everything else to HTTPs as per Caddy’s default behavior but I’m having trouble getting location matching going right.
I basically want to replicate this nginx config:
server {
	listen 80 default_server;
	listen [::]:80 default_server;
	location / {
		return 301 https://$host$request_uri;
	location /check {
		default_type text/plain;
		return 200 "peachy";
If I hit http://example.com/check I get a 200 back directly form Nginx but everything else gets redirected to HTTPS.
I can’t get the pattern matching going in Caddy however. With my config above the second redir catches everything and the first respond doesn’t do anything.
N/A
I’ve tried the above config I’ve pasted along with changing some of the other lines around like:
  respond /check 200
  redir /* https://{host}{uri}
Or
  redir / https://{host}{uri}
  respond /check 200
But I seem to either end up getting Caddy to only respond with a 200 for the /check endpoint and no redirect elsewhere OR a redirect everywhere, and no 200 on the /check endpoint.
Finally let me just thank everyone for Caddy! Its a fantastic piece of software and I’ve genuinely really enjoyed using it. Going to save me a lot of pain having to rejig a lot of janky certificate handling I’ve got going on my application at the moment.
The reason you’re not getting the expected behaviour is because Caddy sorts directives based on a predetermined order, which you can find here:
redir is sorted before respond, regardless of which order you put them in your Caddyfile. To override that order, you should use route which will keep directives in the order they’re listed in your Caddyfile:
http://*.geojs.io {
	route {
		respond /check 200
Ahhh thankyou so much! This is exactly what I needed!
