1. Caddy version:
caddy version
(in the container); unknown
apk info caddy
(in the container): caddy-2.6.2-r2
Caddy runing in podman (docker) container based on alpine:latest
Runs in podman (docker) container like this:
CMD ["caddy", "run", "--config", "/etc/caddy/Caddyfile", "--adapter", "caddyfile"]
alpine:latest, podman (docker)
podman run -it -p 12345:80 -p 12346:443 website_testing:latest
FROM alpine:latest
ARG WEBBUILDTYPE=production
# or testing
RUN apk add --no-cache ca-certificates caddy nss-tools
COPY src /www/prod
COPY server/caddy/Caddyfile_production etc/caddy/Caddyfile_production
COPY server/caddy/Caddyfile_testing etc/caddy/Caddyfile_testing
RUN mv /etc/caddy/Caddyfile /etc/caddy/Caddyfile.bkp.dist
RUN if test "$WEBBUILDTYPE" = 'production'; then ln -s /etc/caddy/Caddyfile_production /etc/caddy/Caddyfile ; else ln -s /etc/caddy/Caddyfile_testing /etc/caddy/Caddyfile ; fi
ENV XDG_DATA_HOME /data
we are talking about the WEBBUILDTYPE=testing
here.
localhost 127.0.0.1 {
redir /staging /staging/
route /staging/* {
uri strip_prefix /staging
basicauth {
staging_user CREDENTIALS_REDACTED
file_server {
root /www/staging
file_server * {
root /www/prod
When I visit the page (127.0.0.1:12346
) on my computer (which is running the container with caddy) I get this:
- chrome:
This site can’t provide a secure connection
127.0.0.1 sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
- firefox:
Secure Connection Failed
An error occurred during a connection to 127.0.0.1:12346. Peer reports it experienced an internal error.
Error code: SSL_ERROR_INTERNAL_ERROR_ALERT
- curl
curl: (35) error:0A000438:SSL routines::tlsv1 alert internal error
wget https://127.0.0.1:12346 --no-check-certificate
--2023-02-04 10:58:50-- https://127.0.0.1:12346/
Connecting to 127.0.0.1:12346... connected.
GnuTLS: A TLS fatal alert has been received.
GnuTLS: received alert [80]: Internal error
Unable to establish SSL connection.
2023/02/04 04:16:13.076 INFO using provided configuration {"config_file": "/etc/caddy/Caddyfile", "config_adapter": "caddyfile"}
2023/02/04 04:16:13.078 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2023/02/04 04:16:13.079 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2023/02/04 04:16:13.079 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2023/02/04 04:16:13.079 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc000760850"}
2023/02/04 04:16:13.080 INFO tls cleaning storage unit {"description": "FileStorage:/data/caddy"}
2023/02/04 04:16:13.080 INFO tls finished cleaning storage units
2023/02/04 04:16:13.093 WARN pki.ca.local installing root certificate (you might be prompted for password) {"path": "storage:pki/authorities/local/root.crt"}
2023/02/04 04:16:13.094 INFO not NSS security databases found
2023/02/04 04:16:13.094 INFO define JAVA_HOME environment variable to use the Java trust
2023/02/04 04:16:13.143 INFO certificate installed properly in linux trusts
2023/02/04 04:16:13.143 INFO http enabling HTTP/3 listener {"addr": ":443"}
2023/02/04 04:16:13.143 INFO failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details.
2023/02/04 04:16:13.144 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2023/02/04 04:16:13.144 INFO http.log server running {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2023/02/04 04:16:13.144 INFO http enabling automatic TLS certificate management {"domains": ["localhost", "127.0.0.1"]}
2023/02/04 04:16:13.144 INFO autosaved config (load with --resume flag) {"file": "/root/.config/caddy/autosave.json"}
2023/02/04 04:16:13.144 INFO serving initial configuration
2023/02/04 04:16:13.144 INFO tls.obtain acquiring lock {"identifier": "127.0.0.1"}
2023/02/04 04:16:13.144 INFO tls.obtain acquiring lock {"identifier": "localhost"}
2023/02/04 04:16:13.145 INFO tls.obtain lock acquired {"identifier": "localhost"}
2023/02/04 04:16:13.145 INFO tls.obtain lock acquired {"identifier": "127.0.0.1"}
2023/02/04 04:16:13.146 INFO tls.obtain obtaining certificate {"identifier": "localhost"}
2023/02/04 04:16:13.146 INFO tls.obtain obtaining certificate {"identifier": "127.0.0.1"}
2023/02/04 04:16:13.148 INFO tls.obtain certificate obtained successfully {"identifier": "127.0.0.1"}
2023/02/04 04:16:13.148 INFO tls.obtain certificate obtained successfully {"identifier": "localhost"}
2023/02/04 04:16:13.148 INFO tls.obtain releasing lock {"identifier": "127.0.0.1"}
2023/02/04 04:16:13.148 INFO tls.obtain releasing lock {"identifier": "localhost"}
2023/02/04 04:16:13.148 WARN tls stapling OCSP {"error": "no OCSP stapling for [127.0.0.1]: no OCSP server specified in certificate", "identifiers": ["127.0.0.1"]}
2023/02/04 04:16:13.148 WARN tls stapling OCSP {"error": "no OCSP stapling for [localhost]: no OCSP server specified in certificate", "identifiers": ["localhost"]}
On production I run same thing but I replace the
in caddy file with actual domains (this is how it runs on pruduction server) it gets certificates from lets encrypt and works properly (I of course persist/data
folder of container on production, on testing I do not) -
The
version that I use here doesn’t work for me. It is meant to be used locally during the development of the website. I expect it to generate self signed certificates on each start of container and then I was hoping I can click sth. likeignore self signed cert
in the browser to continue. Instead I get cryptic error decribed in section 3 and I am not able to visit the website. -
I tried to add:
http_port 12345
https_port 12346
at the beginning of Caddyfile and then run it like podman run -it -p 12345:12345 -p 12346:12346 website:latest
thinking maybe internal/exposed ports number difference matters. It seems it doesn’t.
- I tried to add:
tls internal {
on_demand
same result except now I had to add nss-tools
package into the container for caddy to run
tried to also forward 443/UDP by
podman run -it -p 12345:80 -p 12346:443 -p 12346:443/udp website_testing:latest
without any difference in results -
curl http://127.0.0.1:12346
(calling https port with http) results inClient sent an HTTP request to an HTTPS server.
reply from the server indicating that port forwarding etc. is working properly (there is connection to caddy server). -
lot of google but seem to be running in circles or misunderstanding something here
