Local Server will not start on Port 80
I try to reverse proxy a webservice on a local raspberry pi.
But when I start it it will bind to port 2015.
Port 80 is free. I have tested it by using netstat -tulp.
My Caddyfile contained:
hassbian.local {
	tls off
	proxy / localhost:8123
The output when I start Caddy this is the output:
root@hassbian:/var/www# ./caddy
http://hassbian.local:2015
Hey Flemming, welcome. Very simply, Caddy’s default port is 2015. You can change it to 80 by defining your site address either as http://hassbian.local or hassbian.local:80.
