Hi, I have caddy set up to use my public facing domain. I have that pointing to various docker containers. That works fine. I want to now set it up so if I want to go to jellyfin, for example, I don’t have to type in 192.168.1.150:8096, I can just type watch.home. However, when I set up the reverse proxy how I thought to do it, all requests over http redirect me to just the IP, without a port (takes me to my NAS homepage). I posted my caddyfile, but have tried a ton of different variations like using :443, specifying no port, tls internal, etc.
I am using Pihole as a local DNS with this setup:
text error warn system array login
{"level":"info","ts":1702872036.7006671,"logger":"http","msg":"done waiting on internal rate limiter","identifiers":["request.home"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
{"level":"info","ts":1702872036.7022467,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1702872036.7022526,"msg":"serving initial configuration"}
{"level":"error","ts":1702872036.9418812,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"request.home","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:rejectedIdentifier - Error creating new order :: Cannot issue for \"request.home\": Domain name does not end with a valid public suffix (TLD)"}
{"level":"info","ts":1702872036.9432356,"logger":"http","msg":"waiting on internal rate limiter","identifiers":["request.home"],"ca":"https://acme.zerossl.com/v2/DV90","account":"caddy@zerossl.com"}
{"level":"info","ts":1702872036.9432423,"logger":"http","msg":"done waiting on internal rate limiter","identifiers":["request.home"],"ca":"https://acme.zerossl.com/v2/DV90","account":"caddy@zerossl.com"}
{"level":"error","ts":1702872037.0875914,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"request.home","issuer":"acme.zerossl.com-v2-DV90","error":"[request.home] creating new order: provisioning client: HTTP 503: <html>\r\n<head><title>503 Service Temporarily Unavailable</title></head>\r\n<body>\r\n<center><h1>503 Service Temporarily Unavailable</h1></center>\r\n<hr><center>nginx</center>\r\n</body>\r\n</html>\r\n (ca=https://acme.zerossl.com/v2/DV90)"}
{"level":"error","ts":1702872037.0876317,"logger":"tls.obtain","msg":"will retry","error":"[request.home] Obtain: [request.home] creating new order: provisioning client: HTTP 503: <html>\r\n<head><title>503 Service Temporarily Unavailable</title></head>\r\n<body>\r\n<center><h1>503 Service Temporarily Unavailable</h1></center>\r\n<hr><center>nginx</center>\r\n</body>\r\n</html>\r\n (ca=https://acme.zerossl.com/v2/DV90)","attempt":1,"retrying_in":60,"elapsed":0.389009814,"max_duration":2592000}
{"level":"info","ts":1702872097.0892332,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"request.home"}
{"level":"error","ts":1702872097.353169,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"request.home","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:rejectedIdentifier - Error creating new order :: Cannot issue for \"request.home\": Domain name does not end with a valid public suffix (TLD)"}
{"level":"error","ts":1702872097.386799,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"request.home","issuer":"acme.zerossl.com-v2-DV90","error":"[request.home] creating new order: provisioning client: HTTP 503: <html>\r\n<head><title>503 Service Temporarily Unavailable</title></head>\r\n<body>\r\n<center><h1>503 Service Temporarily Unavailable</h1></center>\r\n<hr><center>nginx</center>\r\n</body>\r\n</html>\r\n (ca=https://acme.zerossl.com/v2/DV90)"}
{"level":"error","ts":1702872097.3868227,"logger":"tls.obtain","msg":"will retry","error":"[request.home] Obtain: [request.home] creating new order: provisioning client: HTTP 503: <html>\r\n<head><title>503 Service Temporarily Unavailable</title></head>\r\n<body>\r\n<center><h1>503 Service Temporarily Unavailable</h1></center>\r\n<hr><center>nginx</center>\r\n</body>\r\n</html>\r\n (ca=https://acme.zerossl.com/v2/DV90)","attempt":2,"retrying_in":120,"elapsed":60.688200714,"max_duration":2592000}
{"level":"info","ts":1702872217.3878748,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"request.home"}
{"level":"error","ts":1702872217.4938257,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"request.home","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:rejectedIdentifier - Error creating new order :: Cannot issue for \"request.home\": Domain name does not end with a valid public suffix (TLD)"}
{"level":"warn","ts":1702872247.6399386,"logger":"http.acme_client","msg":"HTTP request failed; retrying","url":"https://acme.zerossl.com/v2/DV90/newNonce","error":"performing request: Head \"https://acme.zerossl.com/v2/DV90/newNonce\": http2: timeout awaiting response headers (Client.Timeout exceeded while awaiting headers)"}
{"level":"warn","ts":1702872277.8910935,"logger":"http.acme_client","msg":"HTTP request failed; retrying","url":"https://acme.zerossl.com/v2/DV90/newNonce","error":"performing request: Head \"https://acme.zerossl.com/v2/DV90/newNonce\": http2: timeout awaiting response headers (Client.Timeout exceeded while awaiting headers)"}
{"level":"warn","ts":1702872308.142219,"logger":"http.acme_client","msg":"HTTP request failed; retrying","url":"https://acme.zerossl.com/v2/DV90/newNonce","error":"performing request: Head \"https://acme.zerossl.com/v2/DV90/newNonce\": http2: timeout awaiting response headers (Client.Timeout exceeded while awaiting headers)"}
{"level":"error","ts":1702872308.1422727,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"request.home","issuer":"acme.zerossl.com-v2-DV90","error":"[request.home] creating new order: fetching new nonce from server: performing request: Head \"https://acme.zerossl.com/v2/DV90/newNonce\": http2: timeout awaiting response headers (Client.Timeout exceeded while awaiting headers) (ca=https://acme.zerossl.com/v2/DV90)"}
{"level":"error","ts":1702872308.1422887,"logger":"tls.obtain","msg":"will retry","error":"[request.home] Obtain: [request.home] creating new order: fetching new nonce from server: performing request: Head \"https://acme.zerossl.com/v2/DV90/newNonce\": http2: timeout awaiting response headers (Client.Timeout exceeded while awaiting headers) (ca=https://acme.zerossl.com/v2/DV90)","attempt":3,"retrying_in":120,"elapsed":271.443666411,"max_duration":2592000}
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service service-caddy: stopping
{"level":"info","ts":1702872382.440447,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
{"level":"warn","ts":1702872382.440462,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
{"level":"info","ts":1702872382.4404821,"logger":"http","msg":"servers shutting down with eternal grace period"}
{"level":"info","ts":1702872382.4406106,"logger":"tls.obtain","msg":"releasing lock","identifier":"request.home"}
{"level":"info","ts":1702872382.4408197,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
{"level":"info","ts":1702872382.4408293,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
s6-rc: info: service service-caddy successfully stopped
s6-rc: info: service init-setup: stopping
s6-rc: info: service init-setup successfully stopped
s6-rc: info: service init-secrets: stopping
s6-rc: info: service init-secrets successfully stopped
s6-rc: info: service init-perms: stopping
s6-rc: info: service init-perms successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-perms: starting
s6-rc: info: service init-perms successfully started
s6-rc: info: service init-secrets: starting
s6-rc: info: service init-secrets successfully started
s6-rc: info: service init-setup: starting
s6-rc: info: service init-setup successfully started
s6-rc: info: service service-caddy: starting
s6-rc: info: service service-caddy successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
{"level":"info","ts":1702872386.9368484,"msg":"using provided configuration","config_file":"/config/Caddyfile","config_adapter":""}
{"level":"info","ts":1702872386.9389095,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1702872386.9390419,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000613980"}
{"level":"info","ts":1702872386.9398887,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1702872386.9399025,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"warn","ts":1702872386.9399254,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv1","http_port":80}
{"level":"warn","ts":1702872386.9462602,"logger":"pki.ca.local","msg":"installing root certificate (you might be prompted for password)","path":"storage:pki/authorities/local/root.crt"}
{"level":"info","ts":1702872386.9463372,"msg":"warning: \"certutil\" is not available, install \"certutil\" with \"apt install libnss3-tools\" or \"yum install nss-tools\" and try again"}
{"level":"info","ts":1702872386.9463413,"msg":"define JAVA_HOME environment variable to use the Java trust"}
{"level":"error","ts":1702872386.9469514,"logger":"pki.ca.local","msg":"failed to install root certificate","error":"failed to execute tee: exit status 1","certificate_file":"storage:pki/authorities/local/root.crt"}
{"level":"info","ts":1702872386.9470177,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1702872386.9473712,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1702872386.9474971,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
{"level":"info","ts":1702872386.9475155,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["request.home","library-server.exampledomain.com","jackett.exampledomain..com","request.exampledomain..com","movies.exampledomain..com","watch.exampledomain..com","www.exampledomain..com","library.exampledomain..com","tv.exampledomain..com","download.exampledomain..com","books.exampledomain..com"]}
{"level":"warn","ts":1702872386.9484022,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [request.home]: no OCSP server specified in certificate","identifiers":["request.home"]}
{"level":"warn","ts":1702872386.9492655,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/config/caddy","instance":"fc9797af-3498-46ff-883d-cae1927c7c7e","try_again":1702958786.9492645,"try_again_in":86399.999999814}
{"level":"info","ts":1702872386.94939,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1702872386.9549901,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1702872386.9549968,"msg":"serving initial configuration"}
ENVIRONMENT
PUID=99
PGID=100
UMASK=002
TZ=America/Los_Angeles
CUSTOM_BUILD=
Executing usermod...
usermod: no changes
Applying permissions to /config
Running via a docker container on a NAS.
Unraid and docker.
Should run automatically with the container, but if not I run this:
caddy run -c /config/Caddyfile
Using Unraid so no direct ocmpose file.
www.exampledomain {
reverse_proxy 192.168.1.50:3000
basicauth {
myname hashedpw
watch.exampledomain {
reverse_proxy 192.168.1.50:8096
#basicauth {
#myname hashedpw
download.exampledomain{
reverse_proxy 192.168.1.50:8091
basicauth {
myname hashedpw
jackett.exampledomain {
reverse_proxy 192.168.1.50:9117
basicauth {
myname hashedpw
tv.exampledomain {
reverse_proxy 192.168.1.50:8989
basicauth {
myname hashedpw
friend3 hashedpw
movies.exampledomain {
reverse_proxy 192.168.1.50:7878
basicauth {
myname hashedpw
friend3 hashedpw
books.exampledomain {
reverse_proxy 192.168.1.50:8787
basicauth {
myname hashedpw
friend3 hashedpw
library.exampledomain {
reverse_proxy 192.168.1.50:8083 {
header_up X-Scheme https
library-server.exampledomain {
reverse_proxy 192.168.1.50:8084
basicauth {
myname hashedpw
#friend1 hashedpw
#friend2 hashedpw
request.exampledomain {
reverse_proxy 192.168.1.50:5055
#basicauth {
#myname hashedpw
home:80 {
watch.home:80 {
download.home:80 {
jackett.home:80 {
tv.home:80 {
movies.home:80 {
books.home:80 {
manage.home:80 {
reverse_proxy 192.168.1.50/Main
library.home:80 {
library-server.home:80 {
request.home:80 {
