local https works with curl
but not wget
1. Output of caddy version
$ caddy version
2. How I run Caddy
$ brew install caddy
$ caddy run
a. System environment
$ sw_vers
ProductName: macOS
ProductVersion: 12.5
BuildVersion: 21G72
b1. Commands that succeed
opening a browser
$ open https://localhost:443/health
200_CADDYPROXY_OK
curl
$ curl https://localhost:443/health
200_CADDYPROXY_OK
b2. Commands that fail
wget
$ wget https://localhost:443/health
--2022-08-18 18:29:24-- https://localhost/health
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:443... connected.
ERROR: cannot verify localhost's certificate, issued by ‘CN=Caddy Local Authority - ECC Intermediate’:
Unable to locally verify the issuer's authority.
To connect to localhost insecurely, use `--no-check-certificate'
http - eg. httpie https://httpie.io/
$ http https://localhost:443/health
http: error: SSLError: HTTPSConnectionPool(host='localhost', port=443): Max retries exceeded with url: /health (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:997)'))) while doing a GET request to URL: https://localhost:443/health
c. Service/unit/compose file
n/a, running natively
d. My complete Caddy config
http://localhost:80 {
log
respond /health 200_CADDYPROXY_OK
reverse_proxy /example https://example.com:443 {
trusted_proxies private_ranges
tls_insecure_skip_verify
https://localhost:443 {
log
tls internal
tls
tls_server_name example.com
3. The problem I’m having
I want to understand how caddy works with TLS in order to move on to more complex setups, so I would like to know why the wget
option fails here. I would also like to know how curl
is succeeding… is it not checking certs?
4. curl -v
versus wget -vd
output
$ wget -vd https://localhost:443/health
DEBUG output created by Wget 1.21.3 on darwin21.3.0.
Reading HSTS entries from /Users/kai/.wget-hsts
URI encoding = ‘UTF-8’
Converted file name 'health' (UTF-8) -> 'health' (UTF-8)
--2022-08-18 18:38:01-- https://localhost/health
Caching localhost => ::1 127.0.0.1
Created socket 5.
Releasing 0x000060000372fce0 (new refcount 1).
Initiating SSL handshake.
Handshake successful; connected socket 5 to SSL handle 0x00007fb1b2809400
certificate:
subject:
issuer: CN=Caddy Local Authority - ECC Intermediate
To connect to localhost insecurely, use `--no-check-certificate'.
Closed 5/SSL 0x00007fb1b2809400
$ curl -v https://localhost:443/health
* Trying 127.0.0.1:443...
* Connected to localhost (127.0.0.1) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CAfile: /etc/ssl/cert.pem
* CApath: none
* (304) (IN), TLS handshake, Server hello (2):
* (304) (IN), TLS handshake, Unknown (8):
* (304) (IN), TLS handshake, Certificate (11):
* (304) (IN), TLS handshake, CERT verify (15):
* (304) (IN), TLS handshake, Finished (20):
* (304) (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / AEAD-AES128-GCM-SHA256
* subject: [NONE]
* start date: Aug 18 19:09:02 2022 GMT
* expire date: Aug 19 07:09:02 2022 GMT
* subjectAltName: host "localhost" matched cert's "localhost"
* issuer: CN=Caddy Local Authority - ECC Intermediate
* SSL certificate verify ok.
* Using Stream ID: 1 (easy handle 0x7f7999011400)
> GET /health HTTP/2
> Host: localhost
> user-agent: curl/7.79.1
> accept: */*
< HTTP/2 200
< server: Caddy
< content-length: 17
< date: Thu, 18 Aug 2022 22:38:07 GMT
200_CADDYPROXY_OK
5. What I already tried
A shorter Caddyfile produces similar results, eg.
log
