Local domain in hosts file does not work with docker
I’m running caddy in docker with php-fpm and everything is working fine as long as I stick to localhost in the Caddyfile. I will try to run wordpress on the server so I would like to type in a local domain defined in the /etc/hosts file for example https://my-domain.loc.
In /etc/hosts I have an entry → 127.0.0.1 localhost my-domain.loc
Not working Caddyfile: ========================================
my-domain.loc:443 {
php_fastcgi wp-fpm:9000
But if I change my-domain.loc:443 to localhost:443 and type in https://localhost in my browser it works.
Docker compose file extract ========================
container_name: caddy-server275
image: caddy:2.7.5
depends_on:
- mariadb
- phpfpm
cap_add:
  - NET_ADMIN
  - "443:443/udp"
  - /var/www/my-domain.loc:/srv
  - caddy_data:/data
  - caddy_config:/config
    - wp-net
Am I missing something here?
Thanks
dinbox
You’ll need to add tls internal to your site for Caddy to issue a cert using its own CA, like it automatically does for localhost. Or, just use my-domain.localhost (i.e. *.localhost) which Caddy also automatically enables internal for.
Ok will try that, thanks alot!
