1. Output of caddy version
Locally, built with xcaddy run --config caddy.json
Includes private plugin that is almost functionally identical to caddy_rest_storage
(xcaddy version: v0.3.1 h1:XKmnGnGTeB53hLUgnGr/R4JbTNSxh8IBAFcJkrtycso=)
macOS monterrey
./caddy --config config.json
(built with xcaddy
as mentioned above)
"admin": {
"enforce_origin": false,
"listen": "localhost:2018"
"apps": {
"pki": {
"certificate_authorities": {
"local": {
"name": "test-authority",
"root": null
"tls": {
"automation": {
"policies": [
"issuers": [
"module": "internal"
"http": {
"servers": {
"srv0": {
"listen": [
":80",
":443",
":3908"
"routes": [
"match": [
"host": [
"localhost"
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"body": "hello there",
"handler": "static_response"
"terminal": true
"storage": {
"module": "rest",
"endpoint": "http://localhost:3000/tls/rest-storage",
"api_key": "<redacted>"
I’m attempting to test my REST storage plugin (connected to a sql db). I’m getting an error saying the root key does not exist. This is expected because my DB doesn’t have the root key yet, so the REST API returns a 404. However, since root
is null
in my config, the docs say that the root key should be generated for me.
It did however sucessfully create pki/authorities/local/root.crt
2022/09/12 17:29:05.207 INFO using provided configuration {"config_file": "caddy.json", "config_adapter": ""}
2022/09/12 17:29:05.208 INFO admin admin endpoint started {"address": "tcp/localhost:2018", "enforce_origin": false, "origins": ["//localhost:2018", "//[::1]:2018", "//127.0.0.1:2018"]}
run: loading initial config: loading new config: loading pki app module: provision pki: provisioning CA 'local': loading root key: file does not exist
I tried running caddy trust
like so:
./caddy trust --config caddy.json
But of course you need caddy already running, which isn’t possible because of the error above. See error logs:
2022/09/12 17:32:29.177 INFO using provided configuration {"config_file": "caddy.json", "config_adapter": ""}
trust: requesting CA info: performing request: Get "http://localhost:2018/pki/ca/local": dial tcp [::1]:2018: connect: connection refused
