I’m not sure how to map replicas running in a docker container to the load balancer.
And if it’s possible to have a generic solution where I don’t need to manually specify the ports in the Caddyfile for each app?
I`m currently running my app using docker / docker compose:
nodejs-app:
image: ghcr.io/myusername/myrepo:master
container_name: nodejs-app
- backend
- NODE_ENV=production
build:
context: .
deploy:
replicas: 3 # NEW - create 3 replicas
- "8080:8080"
env_file:
- .env
image: caddy:2.8.4-alpine
- backend
- "443:443/udp"
- ./site:/srv
- caddy_data:/data
- caddy_config:/config
caddy_data:
caddy_config:
backend:
driver: bridge
I want to create 3 replicas, and how I should point each of the instances to the Caddy reverse proxy. My current Caddyfile:
email redacted@redacted.com
subdomain.redacted.com {
reverse_proxy nodejs-app:8080 {
header_down Strict-Transport-Security max-age=31536000;
basic_auth {
redacted redacted
N/A
v2.8.4
Running in docker container
In docker, please see above.
Ubuntu 24.04
docker version:
Client: Docker Engine - Community
Version: 27.1.2
API version: 1.46
Go version: go1.21.13
Git commit: d01f264
Built: Mon Aug 12 11:50:54 2024
OS/Arch: linux/amd64
Context: default
Server: Docker Engine - Community
Engine:
Version: 27.1.2
API version: 1.46 (minimum version 1.24)
Git commit: f9522e5
Experimental: false
containerd:
Version: 1.7.20
GitCommit: 8fc6bcff51318944179630522a095cc9dbf9f353
runc:
Version: 1.1.13
GitCommit: v1.1.13-0-g58aa920
docker-init:
Version: 0.19.0
GitCommit: de40ad0
N/A run through docker:
- backend
- "443:443/udp"
- ./site:/srv
- caddy_data:/data
N/A
basic_auth {
redacted redacted
Docker replicas: Compose Deploy Specification | Docker Docs
