I use caddy as load balancer for my docker swarm cluster.
I use dynamic A upstream resolver to get host IPs.
Here is my configuration:
api.globus.furniture {
reverse_proxy {
dynamic a {
name api-service
port 80
lb_policy ip_hash
health_uri /base/health
header_down +X-Used-Endpoint {upstream_hostport}
header_down -server
encode zstd gzip
log
The problem comes with service updates, When I update service of my cluster I get significant downtime.
Docker makes sure a container is up and running before shutting down the previous one, so i think the problem is not with docker setup.
If before update my nodes ips (resolved from dns a record) were:
10.0.0.1
10.0.0.2
10.0.0.3
After update all IPS change.
So for example i will get:
10.0.0.4
10.0.0.5
10.0.0.6
Caddy by default only updates dns records every minute. So depending on the luck, i get up to a minute of downtime.
The solution I see for this is to refresh dns every time upstream health check fails. Or maybe when all upstream health check failed. It can guarantee I will get little to no downtime. But I have no idea how to make it possible with current configuration.
