Load balancing between reverse_proxy
Hello,
Context :
I’m trying to configure a host to serve a nextjs app. In order to avoid any downtime when publishing, I have setup a “blue-green” deployment following this post
Ofc, I don’t use nginx but Caddy so I’m trying to make the configuration for Caddy.
TL;DR, I have two nextjs running through pm2, one on port 3000 and the other one on port 3001.
Only one is running at a time.
The result is a 502 error.
The configuration works if I only have the running nextjs as the reverse_proxy
{"level":"error","ts":1732899944.9000401,"logger":"http.log.error.log0","msg":"dial tcp 127.0.0.1:3001: connect: connection refused","request":{"remote_ip":"80.201.38.152","remote_port":"60471","client_ip":"80.201.38.152","proto":"HTTP/1.1","method":"GET","host":"myhub.inowai.com","uri":"/","headers":{"User-Agent":["curl/8.9.1"],"Accept":["*/*"]},"tls":{"resumed":false,"version":771,"cipher_suite":49195,"proto":"http/1.1","server_name":"myhub.inowai.com"}},"duration":0.006365153,"status":502,"err_id":"8cqe2r7z9","err_trace":"reverseproxy.statusError (reverseproxy.go:1269)"}
v2.8.4
Using the stable release doc on Install — Caddy Documentation
Ubuntu 22.04.4
sudo systemctl (re)start|stop caddy
(common) {
        # security stuff
        header /* {
                -Server
                X-Frame-Options DENY
myhub.inowai.com {
        import common
        encode gzip zstd
        # Storage path for files
        root * /mnt/aiweb
        @exists file
        handle @exists {
        reverse_proxy localhost:3000  localhost:3001
                output file /var/log/caddy/inowai.log {
                        roll_keep 8
                        roll_keep_for 72h
                format json
        tls backend@opp.mx
None of this is correct. Please don’t post AI slob.
Your configuration is close. You’re missing configuring the load balancing policy (directive: lb_policy). Caddy defaults to random, which is why your config might work sometimes. You likely need first, whose documentation says:
first chooses the first available upstream, from the order they are defined in the config, allowing for primary/secondary failover; remember to enable health checks along with this, otherwise failover will not occur.
I think your reverse_proxy part should look like this. The docs recommend having health check so the load balancer knows which upstream is healthy, so consider adding an endpoint that returns 200 when the app is up.
	reverse_proxy localhost:3000 localhost:3001 {
		lb_policy first
		health_uri /health # configure such endpoint in your app
Thank you so much Mohammed, this was the missing pieces !
