Llms.txt [suggestion]
An llms.txt for caddy would be nice. https://llmstxt.org
Can you clarify what you’re asking for?
  1. llms.txt for this website, OR
  2. llms.txt for a Caddy instance?
yes, https://caddyserver.com/llms.txt that contains an ai-readable version of caddy’s docs. so we can more easily ask ai to generate proper config.
This is the repo for Caddy’s website:
If you think adding llms.txt would be worthwhile, feel free to open an issue or submit a PR with your proposal.
with https://gitingest.com i made a text file of all docs: https://github.com/user-attachments/files/20820908/caddyserver-docs.txt. but it can use some cleanup.
