Hi. I have a file_server setup with caddy. I have a public/ directory, which has browse enabled. Now I want to have directory x/ where browse isn’t enabled, but it is enabled for each subdirectory.
vault.chamik.eu/public/ → browsing vault.chamik.eu/x/ → no browsing vault.chamik.eu/x/hello/ → browsing
I figured out the /public/ part, I have trouble with setting up the /x/path.
Also, it can be slightly simplified with file_server browse (i.e. inline the browse option). If you do need to configure other options though, you do need the long-way.
