Caddy version 1.0.4-3
Arch linux, systemd
After=network.target
User=http
Group=http
Environment=CADDYPATH=/var/lib/caddy
EnvironmentFile=-/etc/caddy/envfile
ExecStart=/usr/bin/caddy -log stdout -agree -conf /etc/caddy/caddy.conf -root /tmp
ExecReload=/usr/bin/kill -USR1 $MAINPID
LimitNPROC=64
PrivateDevices=true
ProtectHome=true
ProtectSystem=strict
ReadWriteDirectories=/var/lib/caddy
ReadWriteDirectories=/var/log/caddy
ReadWriteDirectories=/run
d. My complete Caddyfile:
speedtest.wrtpoona.in {
root /var/cache/librespeed
fastcgi / 127.0.0.1:9000 php
# fastcgi / /run/php-fpm/php-fpm.sock php {
# ext .php
# split .php
# log / /var/log/caddy/speedtest_combined.log "{combined}"
errors /var/log/caddy/speedtest_errors.log
tls str@hotmail.com
Caddy works with fastcgi / 127.0.0.1:9000 php but is buggy with fastcgi / /run/php-fpm/php-fpm.sock php as shown commented out above.
There are no errors in the log, but some things will not work, like the gauge for Download speed or the ISP information bits. See https://speedtest.wrtpoona.in for an example.
Project: GitHub - librespeed/speedtest: Self-hosted Speedtest for HTML5 and more. Easy setup, examples, configurable, mobile friendly. Supports PHP, Node, Multiple servers, and more
I assume fastcgi / /run/php-fpm/php-fpm.sock php would be faster being a local socket and would like to get caddy to use that. I would appreciate any pointers.
