LibreNMS .htaccess rewrite conversion
Hi,
I would like to migrate my LibreNMS installation to use Caddy instead of Apache/Nginx but right now I’m stuck with the .htaccess conversion. I already played around with it a bit but I’m not getting all LibreNMS functions (like generated Graphs) to work properly. Would be nice if someone could help me out with the conversion of the default .htaccess rewrite rules:
RewriteEngine on
RewriteBase /
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_URI} !\.(js|ico|txt|gif|jpg|png|css|php)
RewriteRule ^api/v0(.*)$ api_v0.php/$1 [L]
RewriteCond %{REQUEST_URI} !=/server-status
RewriteRule ^(.*)$ index.php/$1/
This should (not tested) also be a working nginx rewrite file if that is easier to convert:
location @librenms {
  rewrite api/v0(.*)$ /api_v0.php/$1 last;
  rewrite ^(.+)$ /index.php/$1 last;
Would be nice to get your help on this!
Something like
example.com {
    rewrite {
        r api/v0(.*)
        to /api_v0.php?{1}
    rewrite {
        r ^(.+)$
        to /index.php/{1}
See docs for rewrite
