Lets Encrypt SSL will no longer issue certificates
Caddy Let’s Encrypt Certificate Issue Support Request
1. The Problem I’m Having
Caddy will not issue a Let’s Encrypt certificate for any domain, full stop. Resulting in an error that isn’t described anywhere on this forum, nor can I find any resources on how to solve this issue.
2. Error Messages and/or Full Log Output
  "level": "error",
  "ts": 1756340527.875998,
  "logger": "tls.obtain",
  "msg": "will retry",
  "error": "[map.redacted.io] Obtain: registering account [mailto:default.json] with server: attempt 1: acme-staging-v02.api.letsencrypt.org/acme/new-acct: HTTP 400 urn:ietf:params:acme:error:invalidContact - Error validating contact(s) :: unable to parse email address",
  "attempt": 2,
  "retrying_in": 120,
  "elapsed": 60.663868785,
  "max_duration": 2592000
3. Caddy Version
caddy:2.9.1-builder-alpine
4. How I Installed and Run Caddy
a. System Environment
Docker, AMD
b. Dockerfile
# syntax=docker/dockerfile:1.4
# Build Go
FROM golang:1.21-alpine AS go-builder
# Install build dependencies
RUN apk add --no-cache gcc musl-dev vips-dev build-base && rm -rf /var/cache/apk/*
# Initialize Go module and build with better error handling
RUN set -ex && \
    go mod init && \
    go get github.com/gofiber/fiber/v2@latest && \
    go get github.com/h2non/bimg@latest && \
    go get github.com/valyala/fasthttp@latest && \
    go mod tidy && \
    CGO_ENABLED=1 GOOS=linux go build -v -o
# Final stage with Caddy
FROM caddy:2.9.1-builder-alpine AS builder
RUN xcaddy build --with --with
# Install runtime dependencies and supervisord
RUN apk add --no-cache vips supervisord nss-tools curl && rm -rf /var/cache/apk/*
# Copy config files
COPY supervisord.conf /etc/supervisor/supervisord.conf
# Copy mysql.json configuration to the exact location
COPY mysql.json /usr/bin/mysql.json
# Ensure correct permissions
RUN chmod 644 /usr/bin/mysql.json
# Create directories
RUN mkdir -p /etc/caddy
# Use EXPOSE for documentation
EXPOSE 80 443 3001
# Set GOGC to off for runtime
ENV GOGC=off
ENV GOMAXPROCS=0
# Use supervisor as entrypoint
CMD ["/usr/bin/supervisord", "-c", "/etc/supervisor/supervisord.conf"]
c. Command (supervisord.conf)
[supervisord]
nodaemon=true
user=root
logfile=/dev/stdout
logfile_maxbytes=0
pidfile=/var/run/supervisord.pid
[program:caddy]
command=caddy run --adapter mysql --config /usr/bin/mysql.json
autostart=true
autorestart=true
stdout_logfile=/dev/stdout
stdout_logfile_maxbytes=0
stderr_logfile=/dev/stderr
stderr_logfile_maxbytes=0
d. Service/Unit/Compose File
  cadx:
    build: .
    network_mode: "host"
5. My Complete Caddy Configuration
Admin Configuration
  "disabled": false,
  "email": "redacted",
  "config": {
    "persist": false
Apps Configuration
HTTP Configuration
  "https_port": 443,
  "servers": {
    "srv0": {
      "listen": [":443"],
      "protocols": ["h1", "h2", "h3"],
      "routes": [
          "handle": [
              "handler": "headers",
              "response": {
                "delete": ["Server", "Etag"],
                "deferred": true
Cache Configuration
  "allowed_http_verbs": ["GET", "HEAD"],
  "cache_name": "Redis-Proxy",
  "default_cache_control": "public, max-age=7200",
  "distributed": true,
  "mode": "bypass",
  "redis": {
    "found": true,
    "configuration": {
      "AlwaysPipelining": true,
      "DisableCache": false,
      "DisableRetry": false,
      "ShuffleInit": true,
      "ClientName": "redacted",
      "InitAddress": ["localhost:6379"]
  "timeout": {
    "backend": "0s",
    "cache": "0s"
  "ttl": "10s"
TLS Configuration
  "automation": {
    "policies": [
        "on_demand": true
    "on_demand": {
      "permission": {
        "module": "http",
        "endpoint": "redacted"
Storage Configuration
  "module": "mysql",
  "query_timeout": 0,
  "lock_timeout": 0,
  "dsn": "redacted"
Server Routes Configuration
  "handle": [
      "handler": "subroute",
      "routes": [
          "handle": [
              "handler": "encode",
              "encodings": {
                "zstd": {
                  "level": "fastest"
                "gzip": {
                  "level": 1
              "prefer": ["zstd"]
              "handler": "cache",
              "handler": "reverse_proxy",
              "transport": {
                "protocol": "http",
                "read_buffer_size": 15360,
                "write_buffer_size": 15360,
                "keep_alive": {
                  "max_idle_conns_per_host": 128
              "headers": {
                "request": {
                  "set": {
                    "Host": ["redacted"]
              "upstreams": [
                  "dial": "redacted"
  "match": [
      "host": ["redacted"]
Correct, Let’s Encrypt issues Let’s Encrypt certificates.
Caddy can request certificates via ACME from Let’s Encrypt as well as other Certificates Authorities for Domain Validation certificates.
Thanks. That really helped.
It looks like you need to set your email address in the tls settings.
I have indeed added the email option, to each block. See above for location, or control-f “email” and you can see where I put it.
And did it help?
It was already present in the current configuration, resulting in the error.
The last time such issue was reported, it was an issue with the storage module. I don’t know what it was, but they were using s3 and said updating the module to latest commit resolved it. That said, s3 has atomicity issue, so don’t consider moving there. I’m just saying it’s a hint it might something to do with storage.
To assist with debugging there is Let’s Debug as a place to start.
And https://unboundtest.com/ as well.
