Layer 4 apt for ssh tunnel
Hi, I am using Caddy as file server on example.com and as reverse proxy on several subdomains. Now I want to utilize my ssh tunnel to get to a machine behind a nat (rpi). I run
 autossh -M 0 -f -o ConnectTimeout=10 -o ServerAliveInterval=60 -o ServerAliveCountMax=2 -i /home/user/.ssh/key -N -R 8080:rpi:22 rnglr.be
In the nat I can ssh to rpi on the standard port.
With caddy running on example.com I need to run the layer 4 app:
  "apps": {
    "layer4": {
      "servers": {
        "example": {
          "listen": [
            "0.0.0.0:8000"
          "routes": [
              "match": [
                  "ssh": []
              "handle": [
                  "handler": "proxy",
                  "upstreams": [
                      "dial": [
                        "localhost:8080"
So now I want to
ssh -p 8000 example.com
to get to rpi on port 22. But it does not work:
ssh: connect to host example.com port 8000: Connection refused
Do I have to install the app somehow? I just loaded the Caddyfile I used and converted it to json and added the layer4 part shown above.
no entries
h1:q3pe0wpBj1OcHFZ3n/1nl4V4bxBrYoSoab7rL9BMYNk=
official packages
Linux ubuntu 6.8.0-49-generic #49-Ubuntu SMP PREEMPT_DYNAMIC x86_64 x86_64 x86_64 GNU/Linux
Ok, I found that I have to install and how to install the layer4 app: Build from source — Caddy Documentation.
Is there a way to get the custom build from Download Caddy via wget onto my machine?
Edit: I managed to install:
wget https://caddyserver.com/api/download?os=linux&arch=amd64&p=github.com%2Fmholt%2Fcaddy-l4&idempotency=35420498813403
I still get a connection refused.
