Latest Authelia v4.38.2 and Caddy issues
After updating Authelia to version v4.38.2 and implementing their new suggested Multi-Domain Protection & Authorization Endpoints i am having issues accessing some of my containers.
Specifically some are working as before but Portainer and Influxdb are refusing to login, they do pass Authelias 2FA just fine which indicates the redirect is working fine but they fail on their own authentication form. If i move the proxy configuration back to “legacy” from “forward-auth” then those two containers do work again.
If i remove “Authorization” and “Proxy-Authorization” from the headers then everything is working but i am not sure if removing them is an ok thing to do.
copy_headers Authorization Proxy-Authorization Remote-User Remote-Groups Remote-Email Remote-Name
I already opened a bug report on the Authelia github but i do wonder if someone here could have any idea of what might be the issue.
Thanx in advance.
Caddy/Portainer do not output any errors in their logs on log level set to info. Below are logs from Influxdb that is complaining during authentication.
ts=2024-03-16T10:56:15.381601Z lvl=info msg=Unauthorized log_id=0nxun9EW000 error="token required"
ts=2024-03-16T10:56:18.744638Z lvl=error msg="api error encountered" log_id=0nxun9EW000 handler=session error="unauthorized access"
ts=2024-03-16T10:56:25.792017Z lvl=error msg="api error encountered" log_id=0nxun9EW000 handler=session error="unauthorized access"
ts=2024-03-16T10:56:33.315416Z lvl=error msg="api error encountered" log_id=0nxun9EW000 handler=session error="unauthorized access"
ts=2024-03-16T10:56:42.326859Z lvl=error msg="api error encountered" log_id=0nxun9EW000 handler=session error="unauthorized access"
Docker compose.
Docker.
b. Service/unit/compose file:
Keep in mind that Portainer is using the old /api/verify to make it work since if i use /api/authz it will not let me login to Portainer.
Grafana is working fine using the new configuration while Portainer and Influxdb fail to login.
            konvei:
                ipv4_address: 172.18.0.2
            - 443:443/udp
        restart: always
            - /home/admin/dockerdata/caddy/data:/data/caddy
            - /home/admin/dockerdata/caddy/logs:/var/log/caddy
            - /home/admin/dockerdata/caddy/config:/config/caddy
            - /home/admin/dockerdata/caddy/config/Caddyfile:/etc/caddy/Caddyfile
            - TZ=Europe/Athens
        cap_add:
            - NET_ADMIN
        image: caddy:latest
    portainer:
            konvei:
                ipv4_address: 172.18.0.3
        container_name: portainer
        depends_on:
            - authelia
        restart: always
            - /usr/share/zoneinfo/Europe/Athens:/etc/localtime
            - /home/admin/dockerdata/portainer/data:/data
        image: portainer/portainer-ce:latest
    grafana:
            konvei:
                ipv4_address: 172.18.0.6
        container_name: grafana
        depends_on:
            - authelia
            - influxdb
        restart: always
        user: "0"
            - /home/admin/dockerdata/grafana/data:/var/lib/grafana
            - /home/admin/dockerdata/grafana/config/custom.ini:/etc/grafana/grafana.ini
        image: grafana/grafana-oss:latest
    authelia:
            konvei:
                ipv4_address: 172.18.0.7
        container_name: authelia
        depends_on:
            - caddy
        restart: always
            - /home/admin/dockerdata/authelia/config:/config
            - /home/admin/dockerdata/authelia/logs:/var/log/authelia
            - AUTHELIA_IDENTITY_VALIDATION_RESET_PASSWORD_JWT_SECRET_FILE=/config/secrets/jwt
            - AUTHELIA_SESSION_SECRET_FILE=/config/secrets/session
            - AUTHELIA_STORAGE_ENCRYPTION_KEY_FILE=/config/secrets/storage
            - AUTHELIA_NOTIFIER_SMTP_PASSWORD_FILE=/config/secrets/smtp
            - TZ=Europe/Athens
        image: authelia/authelia:latest
    influxdb:
            konvei:
                ipv4_address: 172.18.0.10
        container_name: influxdb
        depends_on:
            - authelia
        restart: always
            - /home/admin/dockerdata/influxdb/config:/etc/influxdb2
            - /home/admin/dockerdata/influxdb/data:/var/lib/influxdb2
        image: influxdb:latest
    konvei:
        external: true
c. My complete Caddy config:
	admin off
	email redacted@gmail.com
auth.redacted.pro {
	reverse_proxy http://authelia:9091
		output file /var/log/caddy/authelia.log
redacted.pro www.redacted.pro {
	forward_auth authelia:9091 {
		uri /api/authz/forward-auth
	reverse_proxy http://homepage:3000 {
		output file /var/log/caddy/homepage.log
port.redacted.pro {
                uri /api/verify?rd=https://auth.redacted.pro/
                copy_headers Remote-User Remote-Groups Remote-Name Remote-Email
        reverse_proxy http://portainer:9000 {
                output file /var/log/caddy/portainer.log
info.redacted.pro {
	reverse_proxy http://grafana:3080 {
		output file /var/log/caddy/grafana.log
vpn.redacted.pro {
	reverse_proxy http://wireguard:51821 {
		output file /var/log/caddy/wireguard.log
remote.redacted.pro {
	reverse_proxy http://meshcentral:444 {
		output file /var/log/caddy/meshcentral.log
db.redacted.pro {
	reverse_proxy http://influxdb:8088
		output file /var/log/caddy/influxdb.log
d. My complete Authelia config:
Authelia configuration is done to comply with their new suggested changes in v4.38.2.
Notice that i have both “Legacy” and “ForwardAuth” active in the config, this is done to allow Portainer work for now until i find what is wrong.
server:
address: ‘tcp://0.0.0.0:9091/’
endpoints:
authz:
forward-auth:
implementation: ‘ForwardAuth’
legacy:
implementation: ‘Legacy’
log:
level: ‘info’
format: ‘json’
file_path: ‘/var/log/authelia/authelia.log’
keep_stdout: true
totp:
disable: false
issuer: ‘redacted’
algorithm: ‘sha1’
digits: 6
period: 30
skew: 1
webauthn:
disable: true
authentication_backend:
password_reset:
disable: true
file:
path: ‘/config/users_database.yml’
password:
algorithm: ‘argon2id’
iterations: 1
salt_length: 16
parallelism: 8
memory: 64
access_control:
default_policy: ‘deny’
rules:
- domain:
- ‘auth.redacted.pro’
policy: ‘bypass’
- domain:
- ‘remote.redacted.pro’
policy: ‘bypass’
resources:
- ‘^/meshagents.$’
- '^/meshsettings.
- ‘^/agent.$’
- '^/control.
- ‘^/meshrelay.$’
- '^/sharing.
- ‘^/scripts.$’
- '^/styles.
- ‘^/images.$’
- '^/favicon.
- domain:
- ‘redacted.pro’
- ‘www.redacted.pro’
policy: ‘one_factor’
- domain:
- ‘port.redacted.pro’
- ‘vpn.redacted.pro’
- ‘info.redacted.pro’
- ‘db.redacted.pro’
policy: ‘two_factor’
session:
same_site: ‘lax’
expiration: ‘2h’
inactivity: ‘1h’
remember_me: -1
cookies:
- domain: ‘redacted.pro’
authelia_url: ‘https://auth.redacted.pro
default_redirection_url: ‘https://redacted.pro
regulation:
max_retries: 4
find_time: ‘2m’
ban_time: ‘4h’
theme: dark
storage:
local:
path: ‘/config/db.sqlite3’
notifier:
smtp:
address: ‘smtp://mail.smtp2go.com:587’
username: ‘redacted.pro’
sender: “redacted support@redacted.pro
subject: “[redacted] {title}”
startup_check_address: ‘redacted@gmail.com’
disable_require_tls: false
disable_html_emails: false
tls:
server_name: ‘mail.smtp2go.com
skip_verify: false
minimum_version: ‘TLS1.2’
Adding the whoami results with the authz enabled in case it is helpful.
Hostname: b082e1a8d821
IP: 127.0.0.1
IP: 172.18.0.11
RemoteAddr: 172.18.0.2:44638
GET / HTTP/1.1
Host: whoami.redacted.pro
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:123.0) Gecko/20100101 Firefox/123.0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8
Accept-Encoding: gzip, deflate, br
Accept-Language: en-US,en;q=0.5
Alt-Used: whoami.redacted.pro
Authorization: {http.reverse_proxy.header.Authorization}
Cookie: authelia_session=redacted
Priority: u=1
Referer: https://auth.redacted.pro/
Remote-Email: redacted@gmail.com
Remote-Groups: admins,dev
Remote-Name: KonVei
Remote-User: KonVei
Sec-Fetch-Dest: document
Sec-Fetch-Mode: navigate
Sec-Fetch-Site: same-site
Sec-Fetch-User: ?1
Upgrade-Insecure-Requests: 1
X-Forwarded-For: 94.71.110.150
X-Forwarded-Host: whoami.redacted.pro
X-Forwarded-Proto: https
Yeah this sounds more like an Authelia issue than a Caddy one. All Caddy does is pass through the headers as-is, when configured.
In the example he have in our docs, we don’t have those auth headers forward_auth (Caddyfile directive) — Caddy Documentation but I’ve not kept up on Authelia’s changes. Best if you get clarification from Authelia devs.
Yes, you are correct these are new changes that were added in the latest version of Authelia and the examples for Caddy were adjusted in their documentation as well.
It does indeed seem to be an issue on the Authelia side since there are reports of Traefik having a similar issue after these changes.
The issue was resolved in Authelia v4.38.3 and the documentation has been updated to reflect the new working examples.
