I am trying to use Caddy to reverse proxy to a Kavita Docker image. I am able to access it directly via an IP address + port but I am not able to get it working via reverse_proxy. I have a few services proxied and they are working as-intended. Example request:
* Trying 100.93.230.123:443...
* Connected to shardbearer.banteng-gopher.ts.net (100.93.230.123) port 443 (#0)
* ALPN: offers h2,http/1.1
* CApath: /etc/ssl/certs
* ALPN: server accepted h2
* subject: CN=shardbearer.banteng-gopher.ts.net
* start date: Feb 11 18:01:25 2025 GMT
* expire date: May 12 18:01:24 2025 GMT
* subjectAltName: host "shardbearer.banteng-gopher.ts.net" matched cert's "shardbearer.banteng-gopher.ts.net"
* issuer: C=US; O=Let's Encrypt; CN=E6
* SSL certificate verify ok.
* using HTTP/2
* h2h3 [:method: GET]
* h2h3 [:path: /kavita]
* h2h3 [:scheme: https]
* h2h3 [:authority: shardbearer.banteng-gopher.ts.net]
* h2h3 [user-agent: curl/7.88.1]
* h2h3 [accept: */*]
* Using Stream ID: 1 (easy handle 0x55d405985ce0)
> GET /kavita HTTP/2
> Host: shardbearer.banteng-gopher.ts.net
> accept: */*
< HTTP/2 200
< content-security-policy: frame-ancestors 'none';
< content-type: text/HTML
< date: Thu, 13 Feb 2025 09:52:33 GMT
< last-modified: Thu, 13 Feb 2025 06:20:38 GMT
< server: Caddy
< server: Kestrel
< vary: Accept-Encoding
< x-frame-options: SAMEORIGIN
<!doctype html>
<html lang="en" role="main" data-critters-container>
<head>
<meta charset="utf-8">
<title>Kavita</title>
<base href="/">
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="apple-touch-icon" sizes="180x180" href="assets/icons/apple-touch-icon.png">
<link rel="icon" type="image/png" sizes="32x32" href="assets/icons/favicon-32x32.png">
<link rel="icon" type="image/png" sizes="16x16" href="assets/icons/favicon-16x16.png">
<link rel="manifest" href="site.webmanifest">
<link rel="shortcut icon" href="assets/icons/favicon.ico">
<meta name="msapplication-TileColor" content="#4ac694">
<meta name="msapplication-config" content="assets/icons/browserconfig.xml">
<meta name="theme-color" content="#000000">
<meta name="apple-mobile-web-app-status-bar-style" content="#000000">
<!-- Don't allow indexing from Bots -->
<meta name="robots" content="noindex,nofollow">
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="mobile-web-app-capable" content="yes">
<style>@charset "UTF-8";:root{--swiper-theme-color:#007aff}:root,:root .default{--elevation-layer0:rgba(255,255,255,0);--elevation-layer1:rgba(255,255,255,.05);--elevation-layer2:rgba(255,255,255,.07);--elevation-layer3:rgba(255,255,255,.08);--elevation-layer4:rgba(255,255,255,.09);--elevation-layer5:rgba(255,255,255,.11);--elevation-layer6:rgba(255,255,255,.12);--elevation-layer7:rgba(255,255,255,.14);--elevation-layer8:rgba(255,255,255,.15);--elevation-layer9:rgba(255,255,255,.16);--elevation-layer10:rgba(255,255,255,.4);--elevation-layer0-dark:rgba(0, 0, 0,0);--elevation-layer1-dark:rgba(0, 0, 0,.05);--elevation-layer2-dark:rgba(0, 0, 0,.07);--elevation-layer3-dark:rgba(0, 0, 0,.08);--elevation-layer4-dark:rgba(0, 0, 0,.09);--elevation-layer5-dark:rgba(0, 0, 0,.11);--elevation-layer6-dark:rgba(0, 0, 0,.12);--elevation-layer7-dark:rgba(0, 0, 0,.14);--elevation-layer8-dark:rgba(0, 0, 0,.15);--elevation-layer9-dark:rgba(0, 0, 0,.16);--elevation-layer10-dark:rgba(0, 0, 0, .4);--elevation-layer11-dark:rgba(0, 0, 0, .6);--elevation-layer0-dark-solid:#121212;--elevation-layer1-dark-solid:#1D1D1D;--elevation-layer2-dark-solid:#212121;--elevation-layer3-dark-solid:#242424;--elevation-layer4-dark-solid:#272727;--elevation-layer5-dark-solid:#2C2C2C;--elevation-layer6-dark-solid:#2D2D2D;--elevation-layer7-dark-solid:#323232;--elevation-layer8-dark-solid:#353535;--elevation-layer9-dark-solid:#373737;--primary-color:#4ac694;--primary-color-dark-shade:#3B9E76;--primary-color-darker-shade:#338A67;--primary-color-darkest-shade:#25624A;--error-color:#BD362F;--warning-color:#FFECB5;--bs-body-bg:#1f2020;--body-text-color:#efefef;--btn-icon-filter:invert(1) grayscale(100%) brightness(200%);--primary-color-scrollbar:rgba(255,255,255,.3);--default-state-scrollbar:transparent;--text-muted-color:hsla(0,0%,100%,.45);--colorscape-enabled:true;--colorscape-primary-color:rgb(38, 38, 38);--colorscape-lighter-color:rgb(32, 32, 32);--colorscape-darker-color:rgb(28, 28, 28);--colorscape-complementary-color:rgb(51, 51, 51);--colorscape-primary-alpha-color:rgba(38, 38, 38, 0);--colorscape-lighter-alpha-color:rgba(32, 32, 32, 0);--colorscape-darker-alpha-color:rgba(28, 28, 28, 0);--colorscape-complementary-alpha-color:rgba(51, 51, 51, 0);--colorscape-primary-default-color:rgb(38, 38, 38);--colorscape-lighter-default-color:rgb(32, 32, 32);--colorscape-darker-default-color:rgb(28, 28, 28);--colorscape-complementary-default-color:rgb(51, 51, 51);--theme-color:#000000;--color-scheme:dark;--tile-color:var(--primary-color);--nav-offset:60px;--nav-mobile-offset:55px;--mobile-series-img-background:true;--setting-header-text-color:#d5d5d5;--setting-header-font-size:1.2rem;--setting-header-font-weight:bold;--setting-break-color:rgba(255, 255, 255, .2);--table-header-bg-color:rgba(0,0,0,.15);--table-header-text-color:hsla(0,0%,100%,.9);--table-body-bg-color:hsla(0,0%,100%,.02);--table-body-text-color:hsla(0,0%,100%,.85);--table-body-border:hidden;--table-body-striped-bg-color:var(--elevation-layer2);--navbar-bg-color:black;--navbar-text-color:white;--navbar-fa-icon-color:white;--navbar-border-radius:0px;--navbar-btn-hover-outline-color:rgba(255, 255, 255, 1);--navbar-header-margin:0px;--navbar-header-mobile-x-margin:0px;--navbar-header-mobile-y-margin:0px;--input-bg-color:#343a40;--input-bg-readonly-color:#434648;--input-focused-border-color:#ccc;--input-text-color:#fff;--input-placeholder-color:#aeaeae;--input-border-color:#ccc;--input-focus-boxshadow-color:rgb(255 255 255 / 50%);--btn-focus-boxshadow-color:rgb(255 255 255 / 50%);--btn-primary-text-color:white;--btn-primary-bg-color:var(--primary-color);--btn-primary-border-color:var(--primary-color);--btn-primary-hover-text-color:white;--btn-primary-hover-bg-color:var(--primary-color-darker-shade);--btn-primary-hover-border-color:var(--primary-color-darker-shade);--btn-primary-outline-text-color:white;--btn-primary-outline-bg-color:transparent;--btn-primary-outline-border-color:var(--primary-color);--btn-primary-outline-hover-text-color:white;--btn-primary-outline-hover-bg-color:var(--primary-color-darker-shade);--btn-primary-outline-hover-border-color:var(--primary-color-darker-shade);--btn-secondary-text-color:white;--btn-secondary-bg-color:#6c757d;--btn-secondary-border-color:#6c757d;--btn-secondary-hover-bg-color:var(--bs-btn-hover-bg);--btn-secondary-hover-border-color:var(--bs-btn-hover-border-color);--btn-secondary-font-weight:bold;--btn-secondary-outline-text-color:white;--btn-secondary-outline-bg-color:transparent;--btn-secondary-outline-border-color:transparent;--btn-secondary-outline-hover-bg-color:transparent;--btn-secondary-outline-hover-border-color:transparent;--btn-secondary-outline-font-weight:bold;--btn-primary-text-text-color:white;--btn-secondary-text-text-color:lightgrey;--btn-danger-text-text-color:var(--error-color);--btn-danger-outline-text-color:white;--btn-danger-outline-bg-color:transparent;--btn-danger-outline-border-color:var(--error-color);--btn-danger-outline-hover-text-color:white;--btn-danger-outline-hover-bg-color:var(--error-color);--btn-danger-outline-hover-border-color:var(--error-color);--btn-alt-bg-color:#424c72;--btn-alt-border-color:#444f75;--btn-alt-hover-bg-color:#3b4466;--btn-alt-focus-bg-color:#343c59;--btn-alt-focus-boxshadow-color:rgb(255 255 255 / 50%);--btn-fa-icon-color:white;--btn-disabled-bg-color:#343a40;--btn-disabled-text-color:white;--btn-disabled-border-color:#6c757d;--bs-btn-disabled-border-color:transparent;--btn-actions-border-radius:.375rem;--btn-actions-hover-bg:rgb(255 255 255 / 18%);--nav-item-min-width:150px;--nav-item-max-width:150px;--nav-tab-border-color:rgba(44, 118, 88, .7);--nav-tab-text-color:var(--elevation-layer10);--nav-tab-bg-color:transparent;--nav-tab-border-width:0 0 3px 0;--nav-tab-hover-border-color:var(--primary-color);--nav-tab-active-text-color:white;--nav-tab-border-hover-color:transparent;--nav-tab-hover-text-color:white;--nav-tab-hover-bg-color:transparent;--nav-tab-border-top:transparent;--nav-tab-border-left:transparent;--nav-tab-border-bottom:var(--primary-color);--nav-tab-border-right:transparent;--nav-tab-hover-border-top:transparent;--nav-tab-hover-border-left:transparent;--nav-tab-hover-border-bottom:var(--primary-color);--nav-tab-hover-border-right:transparent;--nav-tab-active-hover-bg-color:transparent;--nav-link-bg-color:var(--primary-color);--nav-link-active-text-color:white;--nav-link-text-color:var(--elevation-layer10);--modal-bg-color:#202122;--nav-header-text-color:white;--nav-header-bg-color:rgb(22, 27, 34);--toast-success-bg-color:rgba(59, 158, 118, .9);--toast-error-bg-color:#BD362F;--toast-info-bg-color:#2F96B4;--toast-warning-bg-color:#F89406;--alert-text-color:#fff3cd;--alert-bg-color:transparent;--checkbox-checked-bg-color:var(--primary-color);--checkbox-border-color:var(--input-focused-border-color);--checkbox-focus-border-color:var(--primary-color);--checkbox-focus-boxshadow-color:rgb(255 255 255 / 50%);--tagbadge-border-color:rgba(239, 239, 239, .125);--tagbadge-text-color:var(--body-text-color);--tagbadge-bg-color:var(--nav-tab-hover-bg-color);--tagbadge-filled-border-color:rgba(239, 239, 239, .125);--tagbadge-filled-text-color:var(--body-text-color);--tagbadge-filled-bg-color:var(--primary-color);--side-nav-width:230px;--side-nav-icon-size:.9rem;--side-nav-bg-color:var(--elevation-layer9-dark);--side-nav-mobile-bg-color:var(--elevation-layer2-dark-solid);--side-nav-openclose-transition:.15s ease-in-out;--side-nav-box-shadow:var(--elevation-layer0);--side-nav-mobile-box-shadow:3px 0em 5px 10em rgb(0 0 0 / 50%);--side-nav-hover-text-color:white;--side-nav-hover-bg-color:black;--side-nav-text-color:hsla(0,0%,100%,.85);--side-nav-border-radius:3px;--side-nav-border:none;--side-nav-border-closed:none;--side-nav-border-transition:.5s ease-in-out;--side-nav-companion-bar-transistion:.15s linear;--side-nav-bg-color-transition:.5s ease-in-out;--side-nav-closed-bg-color:transparent;--side-nav-item-active-color:var(--primary-color);--side-nav-item-active-text-color:#fff;--side-nav-active-bg-color:transparent;--side-nav-overlay-color:var(--elevation-layer11-dark);--side-nav-item-closed-color:var(--elevation-layer10);--side-nav-item-closed-hover-color:white;--list-group-item-text-color:var(--body-text-color);--list-group-item-bg-color:transparent;--search-list-group-item-bg-color:rgb(32, 38, 41);--list-group-hover-text-color:white;--list-group-hover-bg-color:rgb(22, 27, 34);--list-group-active-border-color:none;--list-group-item-border-top-left-radius:0px;--list-group-item-border-top-right-radius:0px;--list-group-item-border-bottom-left-radius:0px;--list-group-item-border-bottom-right-radius:0px;--list-group-item-border-width:1px 0 1px 0;--list-group-item-border-color:rgba(239, 239, 239, .125);--list-group-item-border-style:solid;--list-group-item-first-border-width:0px 0px 1px 0px;--list-group-item-last-border-width:0px 0px 0px 0px;--popover-body-bg-color:#2C2C2C;--popover-body-text-color:var(--navbar-text-color);--popover-outerarrow-color:transparent;--popover-arrow-color:transparent;--popover-bg-color:black;--popover-border-color:black;--pagination-active-link-border-color:var(--primary-color);--pagination-active-link-bg-color:var(--primary-color);--pagination-active-link-text-color:white;--pagination-link-border-color:rgba(239, 239, 239, .125);--pagination-link-text-color:white;--pagination-link-bg-color:rgba(1, 4, 9, .5);--pagination-focus-border-color:var(--primary-color);--pagination-link-hover-color:var(--primary-color);--progress-striped-animated-color:linear-gradient(45deg, rgba(74,198,148, .75) 25%, rgba(51, 138, 103, .75) 25%, rgba(51, 138, 103, .75) 50%, rgba(74,198,148, .75) 50%, rgba(74,198,148, .75) 75%, rgba(51, 138, 103, .75) 75%, rgba(51, 138, 103, .75));--progress-bg-color:var(--nav-header-bg-color);--progress-bar-color:var(--primary-color-dark-shade);--dropdown-item-hover-text-color:white;--dropdown-item-hover-bg-color:var(--primary-color-dark-shade);--dropdown-item-text-color:var(--navbar-text-color);--dropdown-item-bg-color:#2C2C2C;--dropdown-overlay-color:var(--elevation-layer1);--accordion-header-text-color:rgba(74, 198, 148, .9);--accordion-header-bg-color:rgba(52, 60, 70, .5);--accordion-body-bg-color:#292929;--accordion-body-border-color:rgba(239, 239, 239, .125);--accordion-body-text-color:var(--body-text-color);--accordion-header-collapsed-text-color:rgba(74, 198, 148, .9);--accordion-header-collapsed-bg-color:#292929;--accordion-button-focus-border-color:unset;--accordion-button-focus-box-shadow:unset;--accordion-active-body-bg-color:#292929;--accordion-body-box-shadow:none;--breadcrumb-bg-color:#292d32;--breadcrumb-item-text-color:var(--body-text-color);--ratingstar-color:white;--rating-star-color:var(--primary-color);--ratingstar-star-empty:#b0c4de;--ratingstar-star-filled:var(--primary-color);--hr-color:rgba(239, 239, 239, .125);--accent-bg-color:rgba(1, 4, 9, .5);--accent-text-color:lightgrey;--grid-breakpoints-xs:$grid-breakpoints-xs;--grid-breakpoints-sm:$grid-breakpoints-sm;--grid-breakpoints-md:$grid-breakpoints-md;--grid-breakpoints-lg:$grid-breakpoints-lg;--grid-breakpoints-xl:$grid-breakpoints-xl;--body-font-family:"EBGaramond", "Helvetica Neue", sans-serif;--brand-font-family:"Spartan", sans-serif;--html-font-size:16px;--card-bg-color:var(--elevation-layer3);--card-text-color:var(--body-text-color);--card-border-width:0 1px 1px 1px;--card-border-style:solid;--card-border-color:transparent;--card-border-radius:5px;--card-progress-bar-color:var(--primary-color);--card-overlay-bg-color:rgba(0, 0, 0, 0);--card-overlay-hover-bg-color:rgba(30,30,30,.6);--card-progress-triangle-size:28px;--slider-text-color:white;--input-range-color:var(--primary-color);--input-range-active-color:var(--primary-color-darker-shade);--manga-reader-overlay-filter:blur(10px);--manga-reader-overlay-bg-color:rgba(0,0,0,.5);--manga-reader-overlay-text-color:white;--manga-reader-next-highlight-bg-color:rgba(65, 225, 100, .5);--manga-reader-prev-highlight-bg-color:rgba(65, 105, 225, .5);--radio-accent-color:var(--primary-color);--radio-hover-accent-color:var(--primary-color);--radio-focus-boxshadow-color:rgb(255 255 255 / 50%);--carousel-header-text-color:var(--body-text-color);--carousel-header-text-decoration:none;--carousel-hover-header-text-decoration:none;--carousel-btn-color:var(--body-text-color);--drawer-bg-color:#292929;--drawer-text-color:white;--event-widget-bg-color:rgb(1, 4, 9);--event-widget-item-bg-color:rgb(1, 4, 9);--event-widget-text-color:var(--body-text-color);--event-widget-item-border-color:rgba(53, 53, 53, .5);--event-widget-border-color:rgba(1, 4, 9, .5);--event-widget-info-bg-color:#b6d4fe;--event-widget-error-bg-color:var(--error-color);--event-widget-update-bg-color:var(--primary-color);--event-widget-activity-bg-color:var(--primary-color);--search-result-text-lite-color:initial;--searchbar-bg-color:rgb(255 255 255 / 12%);--bulk-selection-text-color:var(--navbar-text-color);--bulk-selection-highlight-text-color:var(--primary-color);--bulk-selection-bg-color:black;--card-list-item-bg-color:linear-gradient(180deg, rgba(0,0,0,.15) 0%, rgba(0,0,0,.15) 1%, rgba(0,0,0,0) 100%);--review-card-star-color:gold;--review-spoiler-bg-color:var(--primary-color);--review-spoiler-text-color:var(--body-text-color);--badge-text-color:var(--bs-badge-color);--login-card-bg-color:#212121;--login-logo-image:url(/assets/images/logo.png);--login-logo-height:55px;--login-logo-width:55px;--login-logo-bg-size:contain;--login-logo-bg-repeat:no-repeat;--login-card-border-width:3px 0px 0px 0px;--login-card-border-style:solid;--login-card-border-color:var(--primary-color);--login-input-border-color:transparent;--login-input-border-color-focus:transparent;--login-input-box-shadow-focus:0 0 0 1px rgba(74, 198, 148, .8);--login-input-background-color:#353535;--login-input-color:#fff;--login-forgot-password-color:var(--primary-color);--login-background-url:url("./media/login-bg-3F52TUWZ.jpg");--login-background-size:cover;--login-background-opacity:.3;--login-background-color:#000;--login-input-font-family:"League Spartan", sans-serif;--login-input-placeholder-opacity:.5;--login-input-placeholder-color:#fff}:root{--bs-blue:#0d6efd;--bs-indigo:#6610f2;--bs-purple:#6f42c1;--bs-pink:#d63384;--bs-red:#dc3545;--bs-orange:#fd7e14;--bs-yellow:#ffc107;--bs-green:#198754;--bs-teal:#20c997;--bs-cyan:#0dcaf0;--bs-black:#000;--bs-white:#fff;--bs-gray:#6c757d;--bs-gray-dark:#343a40;--bs-gray-100:#f8f9fa;--bs-gray-200:#e9ecef;--bs-gray-300:#dee2e6;--bs-gray-400:#ced4da;--bs-gray-500:#adb5bd;--bs-gray-600:#6c757d;--bs-gray-700:#495057;--bs-gray-800:#343a40;--bs-gray-900:#212529;--bs-primary:#4ac694;--bs-danger:#BD362F;--bs-secondary:#6c757d;--bs-light:#f8f9fa;--bs-primary-rgb:74, 198, 148;--bs-danger-rgb:189, 54, 47;--bs-secondary-rgb:108, 117, 125;--bs-light-rgb:248, 249, 250;--bs-primary-text-emphasis:#052c65;--bs-secondary-text-emphasis:#2b2f32;--bs-success-text-emphasis:#0a3622;--bs-info-text-emphasis:#055160;--bs-warning-text-emphasis:#664d03;--bs-danger-text-emphasis:#58151c;--bs-light-text-emphasis:#495057;--bs-dark-text-emphasis:#495057;--bs-primary-bg-subtle:#cfe2ff;--bs-secondary-bg-subtle:#e2e3e5;--bs-success-bg-subtle:#d1e7dd;--bs-info-bg-subtle:#cff4fc;--bs-warning-bg-subtle:#fff3cd;--bs-danger-bg-subtle:#f8d7da;--bs-light-bg-subtle:#fcfcfd;--bs-dark-bg-subtle:#ced4da;--bs-primary-border-subtle:#9ec5fe;--bs-secondary-border-subtle:#c4c8cb;--bs-success-border-subtle:#a3cfbb;--bs-info-border-subtle:#9eeaf9;--bs-warning-border-subtle:#ffe69c;--bs-danger-border-subtle:#f1aeb5;--bs-light-border-subtle:#e9ecef;--bs-dark-border-subtle:#adb5bd;--bs-white-rgb:255, 255, 255;--bs-black-rgb:0, 0, 0;--bs-font-sans-serif:system-ui, -apple-system, "Segoe UI", Roboto, "Helvetica Neue", "Noto Sans", "Liberation Sans", Arial, sans-serif, "Apple Color Emoji", "Segoe UI Emoji", "Segoe UI Symbol", "Noto Color Emoji";--bs-font-monospace:SFMono-Regular, Menlo, Monaco, Consolas, "Liberation Mono", "Courier New", monospace;--bs-gradient:linear-gradient(180deg, rgba(255, 255, 255, .15), rgba(255, 255, 255, 0));--bs-body-font-family:var(--bs-font-sans-serif);--bs-body-font-size:1rem;--bs-body-font-weight:400;--bs-body-line-height:1.5;--bs-body-color:#212529;--bs-body-color-rgb:33, 37, 41;--bs-body-bg:#fff;--bs-body-bg-rgb:255, 255, 255;--bs-emphasis-color:#000;--bs-emphasis-color-rgb:0, 0, 0;--bs-secondary-color:rgba(33, 37, 41, .75);--bs-secondary-color-rgb:33, 37, 41;--bs-secondary-bg:#e9ecef;--bs-secondary-bg-rgb:233, 236, 239;--bs-tertiary-color:rgba(33, 37, 41, .5);--bs-tertiary-color-rgb:33, 37, 41;--bs-tertiary-bg:#f8f9fa;--bs-tertiary-bg-rgb:248, 249, 250;--bs-heading-color:inherit;--bs-link-color:#0d6efd;--bs-link-color-rgb:13, 110, 253;--bs-link-decoration:underline;--bs-link-hover-color:#0a58ca;--bs-link-hover-color-rgb:10, 88, 202;--bs-code-color:#d63384;--bs-highlight-color:#212529;--bs-highlight-bg:#fff3cd;--bs-border-width:1px;--bs-border-style:solid;--bs-border-color:#dee2e6;--bs-border-color-translucent:rgba(0, 0, 0, .175);--bs-border-radius:.375rem;--bs-border-radius-sm:.25rem;--bs-border-radius-lg:.5rem;--bs-border-radius-xl:1rem;--bs-border-radius-xxl:2rem;--bs-border-radius-2xl:var(--bs-border-radius-xxl);--bs-border-radius-pill:50rem;--bs-box-shadow:0 .5rem 1rem rgba(0, 0, 0, .15);--bs-box-shadow-sm:0 .125rem .25rem rgba(0, 0, 0, .075);--bs-box-shadow-lg:0 1rem 3rem rgba(0, 0, 0, .175);--bs-box-shadow-inset:inset 0 1px 2px rgba(0, 0, 0, .075);--bs-focus-ring-width:.25rem;--bs-focus-ring-opacity:.25;--bs-focus-ring-color:rgba(13, 110, 253, .25);--bs-form-valid-color:#198754;--bs-form-valid-border-color:#198754;--bs-form-invalid-color:#dc3545;--bs-form-invalid-border-color:#dc3545}*,*:before,*:after{box-sizing:border-box}@media (prefers-reduced-motion: no-preference){:root{scroll-behavior:smooth}}body{margin:0;font-family:var(--bs-body-font-family);font-size:var(--bs-body-font-size);font-weight:var(--bs-body-font-weight);line-height:var(--bs-body-line-height);color:var(--bs-body-color);text-align:var(--bs-body-text-align);background-color:var(--bs-body-bg);-webkit-text-size-adjust:100%;-webkit-tap-highlight-color:rgba(0,0,0,0)}:root{--bs-breakpoint-xs:0;--bs-breakpoint-sm:576px;--bs-breakpoint-md:768px;--bs-breakpoint-lg:992px;--bs-breakpoint-xl:1200px}@property --color-1{syntax:"<color>";initial-value:transparent;inherits:true}@property --color-2{syntax:"<color>";initial-value:transparent;inherits:true}@property --color-3{syntax:"<color>";initial-value:transparent;inherits:true}@property --color-4{syntax:"<color>";initial-value:transparent;inherits:true}@property --color-5{syntax:"<color>";initial-value:transparent;inherits:true}@property --color-6{syntax:"<color>";initial-value:transparent;inherits:true}@property --color-7{syntax:"<color>";initial-value:transparent;inherits:true}@property --color-8{syntax:"<color>";initial-value:transparent;inherits:true}@property --color-9{syntax:"<color>";initial-value:transparent;inherits:true}@property --color-10{syntax:"<color>";initial-value:transparent;inherits:true}@property --color{syntax:"<color>";inherits:true}@property --chart-bg-color{syntax:"<color>";inherits:true}@property --aspect-ratio{syntax:"<ratio>";initial-value:auto;inherits:true}@property --labels-size{syntax:"<length>";initial-value:0;inherits:true}@property --labels-align-block{syntax:"<string>";inherits:true}@property --labels-align-inline{syntax:"<string>";inherits:true}@property --primary-axis-width{syntax:"<length>";initial-value:1px;inherits:true}@property --secondary-axes-width{syntax:"<length>";initial-value:1px;inherits:true}@property --data-axes-width{syntax:"<length>";initial-value:1px;inherits:true}@property --legend-border-width{syntax:"<length>";initial-value:1px;inherits:true}@property --primary-axis-style{syntax:"<line-style>";initial-value:solid;inherits:true}@property --secondary-axes-style{syntax:"<line-style>";initial-value:solid;inherits:true}@property --data-axes-style{syntax:"<line-style>";initial-value:solid;inherits:true}@property --legend-border-style{syntax:"<line-style>";initial-value:solid;inherits:true}@property --primary-axis-color{syntax:"<color>";initial-value:transparent;inherits:true}@property --secondary-axes-color{syntax:"<color>";initial-value:transparent;inherits:true}@property --data-axes-color{syntax:"<color>";initial-value:transparent;inherits:true}@property --legend-border-color{syntax:"<color>";initial-value:transparent;inherits:true}@property --start{syntax:"<number>";inherits:true}@property --end{syntax:"<number>";inherits:true}@property --size{syntax:"<number>";inherits:true}@property --line-size{syntax:"<number>";inherits:true}:root{--select2-single-height:36px;--select2-multiple-height:36px;--select2-label-text-color:#000;--select2-required-color:red;--select2-selection-border-radius:4px;--select2-selection-background:var(--input-bg-readonly-color);--select2-selection-disabled-background:#eee;--select2-selection-border-color:var(--input-border-color);--select2-selection-focus-border-color:var(--input-focus-boxshadow-color);--select2-selection-text-color:var(--input-text-color);--select2-selection-choice-background:var(--tagbadge-filled-bg-color);--select2-selection-choice-text-color:var(--tagbadge-filled-text-color);--select2-selection-choice-border-color:var(--tagbadge-border-color);--select2-selection-choice-close-color:var(--tagbadge-filled-text-color);--select2-selection-choice-hover-close-color:var(--tagbadge-filled-text-color);--select2-placeholder-color:#999;--select2-placeholder-overflow:ellipsis;--select2-no-result-color:#888;--select2-no-result-font-style:italic;--select2-too-much-result-color:#888;--select2-too-much-result-style:italic;--select2-reset-color:#999;--select2-arrow-color:#ccc;--select2-dropdown-background:var(--input-bg-readonly-color);--select2-dropdown-border-color:var(--input-border-color);--select2-overlay-backdrop:transparent;--select2-search-border-color:var(--input-border-color);--select2-search-background:var(--input-bg-readonly-color);--select2-search-border-radius:0px;--select2-option-text-color:var(--body-text-color);--select2-option-disabled-text-color:#999;--select2-option-disabled-background:transparent;--select2-option-selected-text-color:lightgrey;--select2-option-selected-background:var(--btn-disabled-bg-color);--select2-option-highlighted-text-color:#fff;--select2-option-highlighted-background:#5897fb;--select2-option-group-text-color:var(--body-text-color);--select2-option-group-background:transparent;--select2-hint-text-color:#888}html{font-size:var(--html-font-size)}html,body{height:100%;overflow:hidden}body{margin:0;font-family:var(--body-font-family);color:var(--body-text-color);color-scheme:var(--color-scheme);max-height:100%;overflow-y:auto}@font-face{font-family:Spartan;src:url("./media/Spartan-VariableFont_wght-NM2LR5HQ.woff2") format("woff2");font-display:swap}@font-face{font-family:Poppins;src:url("./media/Poppins-SFWTNBQB.woff2") format("woff2");font-display:swap}@font-face{font-family:League Spartan;src:url("./media/LeagueSpartan-VariableFont_wght-2EBMJPE4.ttf");font-display:swap}app-root{scrollbar-width:thin;scrollbar-color:rgba(255,255,255,.3)}body{font-family:Poppins,sans-serif;overflow:hidden;scrollbar-color:rgba(255,255,255,.3) rgba(0,0,0,.1);scrollbar-width:thin;padding:0;margin:0}:root{--fa-style-family-brands:"Font Awesome 6 Brands";--fa-font-brands:normal 400 1em/1 "Font Awesome 6 Brands"}@font-face{font-family:"Font Awesome 6 Brands";font-style:normal;font-weight:400;font-display:block;src:url("./media/fa-brands-400-MDS4TU4L.woff2") format("woff2"),url("./media/fa-brands-400-CNBICIQT.ttf") format("truetype")}:root{--fa-font-regular:normal 400 1em/1 "Font Awesome 6 Free"}@font-face{font-family:"Font Awesome 6 Free";font-style:normal;font-weight:400;font-display:block;src:url("./media/fa-regular-400-N56QV3DR.woff2") format("woff2"),url("./media/fa-regular-400-2FI4ICQD.ttf") format("truetype")}:root{--fa-style-family-classic:"Font Awesome 6 Free";--fa-font-solid:normal 900 1em/1 "Font Awesome 6 Free"}@font-face{font-family:"Font Awesome 6 Free";font-style:normal;font-weight:900;font-display:block;src:url("./media/fa-solid-900-Z3HFQTXF.woff2") format("woff2"),url("./media/fa-solid-900-XVWCCN5V.ttf") format("truetype")}</style><link rel="stylesheet" href="styles-OSMUEMQ3.css" media="print" onload="this.media='all'"><noscript><link rel="stylesheet" href="styles-OSMUEMQ3.css"></noscript></head>
<body class="mat-typography default" theme="dark">
<app-root></app-root>
<noscript>Please enable JavaScript to continue using this application.</noscript>
<link rel="modulepreload" href="chunk-MFNSJITH.js"><link rel="modulepreload" href="chunk-VIBKPRU6.js"><link rel="modulepreload" href="chunk-BXJYX7MP.js"><link rel="modulepreload" href="chunk-E7ZRNGXF.js"><link rel="modulepreload" href="chunk-K3WBUCUC.js"><link rel="modulepreload" href="chunk-AF43YU3D.js"><link rel="modulepreload" href="chunk-ZP7F2M2I.js"><link rel="modulepreload" href="chunk-HCPIVMPE.js"><link rel="modulepreload" href="chunk-DNPS474R.js"><link rel="modulepreload" href="chunk-7NMVE5II.js"><script src="polyfills-KSD5EUEV.js" type="module"></script><script src="main-GA3JORTM.js" type="module"></script></body>
</html>
* Connection #0 to host shardbearer.banteng-gopher.ts.net left intact
Loading module from “https://shardbearer.banteng-gopher.ts.net/chunk-MFNSJITH.js” was blocked because of a disallowed MIME type (“text/html”).
nicfitzgerald@shardbearer:~/docker$ caddy version
2.6.2
I followed the official installation guide and installed it using sudo apt install caddy
I am running Debian 12 AMD64. I have Docker installed but it is unrelated to Caddy. For sake of never too much info:
nicfitzgerald@shardbearer:~/docker$ docker version
Client: Docker Engine - Community
Version: 27.5.1
API version: 1.47
Go version: go1.22.11
Git commit: 9f9e405
Built: Wed Jan 22 13:41:17 2025
OS/Arch: linux/amd64
Context: default
Server: Docker Engine - Community
Engine:
Version: 27.5.1
API version: 1.47 (minimum version 1.24)
Git commit: 4c9b3b0
Experimental: false
containerd:
Version: 1.7.25
GitCommit: bcc810d6b9066471b0b6fa75f557a15a1cbf31bb
runc:
Version: 1.2.4
GitCommit: v1.2.4-0-g6c52b3f
docker-init:
Version: 0.19.0
GitCommit: de40ad0
caddy fmt --overwrite Caddyfile
Kavita Docker Compose file:
kavita:
image: lscr.io/linuxserver/kavita:latest
container_name: kavita
- PUID=$PUID
- PGID=$PGID
- TZ=$TZ
- DOTNET_SYSTEM_GLOBALIZATION_INVARIANT=true
- $DOCKERDIR/appdata/kavita/data:/config
- $BULKDIR/Comics:/comics
- $BULKDIR/Manga:/manga
- socket_proxy
shardbearer.banteng-gopher.ts.net {
handle_path /calibre-web* {
reverse_proxy 100.93.230.123:8083 {
header_up X-Scheme https
header_up X-Script-Name /calibre-web
handle_path /audiobookshelf* {
encode gzip zstd
reverse_proxy 100.93.230.123:8090
handle_path /kavita* {
reverse_proxy * 100.93.230.123:5000 {
header_up X-Forwarded-Host {host}:5000
header_up -Origin
header_up -Referer
reverse_proxy 100.93.230.123:3000
Kavita has their own Caddy example (Kavita Caddy Example) but I was not able to get it to work.
