Issues with TLS Handshake on iOS 16
I running Caddy as a reverse proxy to serve Matrix Synapse Server. The configuration is the bare minimum and worked well.
Now I ran into a problem with the Element iOS client. The networking stopped (randomly) working and the client seems to endless loading. I digged into the problem and debugged the Element for iOS and received this logs:
2023-04-29 12:13:37.341322+0200 Element[76705:4662274] [boringssl] boringssl_session_handshake_incomplete(88) [C12.1.2.1:2][0x123220370] SSL library error
2023-04-29 12:13:37.345932+0200 Element[76705:4662274] [boringssl] boringssl_session_handshake_error_print(43) [C12.1.2.1:2][0x123220370] Error: 4850737128:error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED:/Library/Caches/com.apple.xbs/Sources/boringssl_Sim/ssl/handshake.cc:419:
2023-04-29 12:13:37.346013+0200 Element[76705:4662274] [boringssl] nw_protocol_boringssl_handshake_negotiate_proceed(771) [C12.1.2.1:2][0x123220370] handshake failed at state 12288: not completed
2023-04-29 12:13:37.346285+0200 Element[76705:4662274] [boringssl] boringssl_context_handle_fatal_alert(1991) [C12.1.2.2:2][0x14c5b73d0] write alert, level: fatal, description: certificate unknown
2023-04-29 12:13:37.346336+0200 Element[76705:4662274] [boringssl] boringssl_context_error_print(1981) [C12.1.2.2:2][0x14c5b73d0] Error: 4850737128:error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED:/Library/Caches/com.apple.xbs/Sources/boringssl_Sim/ssl/handshake.cc:419:
2023-04-29 12:13:37.346460+0200 Element[76705:4662274] [boringssl] boringssl_session_handshake_incomplete(88) [C12.1.2.2:2][0x14c5b73d0] SSL library error
2023-04-29 12:13:37.346510+0200 Element[76705:4662274] [boringssl] boringssl_session_handshake_error_print(43) [C12.1.2.2:2][0x14c5b73d0] Error: 4850737128:error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED:/Library/Caches/com.apple.xbs/Sources/boringssl_Sim/ssl/handshake.cc:419:
2023-04-29 12:13:37.346561+0200 Element[76705:4662274] [boringssl] nw_protocol_boringssl_handshake_negotiate_proceed(771) [C12.1.2.2:2][0x14c5b73d0] handshake failed at state 12288: not completed
Why I ask this here you might ask and I also tried different networks, reinstall the App and at the end I used them in an airgapped environment to reproduce this scenario. But the solution was to restart Caddy. So I tried to find out why iOS was not able to do the handshake and found a document which outlines the requirements for TLS on iOS: Apple's Certificate Transparency policy - Apple Support
There is also an Stackoverflow post existing targeting this issue: nginx - Secure websocket connection fails on iOS due to BoringSSL certificate verification failure - Stack Overflow
It could be related with OCSP Stapling and Signed Certificate Timestamps. Therefore I seek for a Caddy Pro which can help me to dig deeper and maybe shed some light in this section and how Caddy works in that section.
There is no log present because of not enabled debug and the problem is before the connection is established.
v2.6.4
OS: Debian Bullseye
ARCH: amd64
Service file:
Restart=on-failure
StartLimitInterval=600
# Service security
NoNewPrivileges=yes
PrivateTmp=yes
PrivateDevices=yes
DevicePolicy=closed
ProtectControlGroups=yes
ProtectKernelModules=yes
ProtectKernelTunables=yes
RestrictAddressFamilies=AF_UNIX AF_INET AF_INET6 AF_NETLINK
RestrictNamespaces=yes
RestrictRealtime=yes
MemoryDenyWriteExecute=yes
LockPersonality=yes
ProtectHome=true
CapabilityBoundingSet=~CAP_SYS_ADMIN CAP_SYS_PTRACE CAP_SETUID CAP_SETGID CAP_SETPCAP CAP_CHOWN CAP_FSETID CAP_SETFCAP CAP_NET_ADMIN CAP_SYS_TIME
ProtectClock=true
ProtectKernelLogs=true
ProtectProc=invisible
My complete Caddy config:
email admin@example.org
matrix.example.org {
  reverse_proxy http://matrix1:80 {
    header_down -Server
matrix.example.org:8448 {
  reverse_proxy http://matrix1:8448 {
    header_down -Server
I’ve had this same problem happen to me twice now. When caddy is restarted it keeps using a certificate it has requested previously. When that certificate gets within 30(?) days of expiry caddy requests a new one and starts using it. So far all seems to be good.
The problem appears when the original certificate expires 30 days later and Element iOS stops working. It seems for some reason caddy keeps serving Element iOS the original certificate instead of the renewed one. Once caddy is restarted, it seems to forget about the outdated certificate and starts serving the renewed one correctly.
Is Element client (iOS 16) using HTTP/3 perchance?
It seems it use HTTP/2. I started Element in Simulator on macOS (same way I reproduced the problem) and saw only TCP Connections. HTTP/3 should be over UDP, right?
