I am unable to connect to a gRPC service behind a Caddy reverse-proxy using http and private IP address. Using https works just as expected.
It is most likely an issue on my side or a misunderstanding of the conception in Caddy + gRPC, but I am not getting logs of the requests on Caddy.
To validate things if I by pass caddy the client connects as expected.
No error or request logs from Caddy’s output:
getting-started-caddy-1 | {"level":"info","ts":1690876430.9027994,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
getting-started-caddy-1 | {"level":"warn","ts":1690876430.9044518,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
getting-started-caddy-1 | {"level":"info","ts":1690876430.90604,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
getting-started-caddy-1 | {"level":"warn","ts":1690876430.9064245,"logger":"http","msg":"automatic HTTPS is completely disabled for server","server_name":"srv0"}
getting-started-caddy-1 | {"level":"warn","ts":1690876430.9064693,"logger":"http","msg":"automatic HTTPS is completely disabled for server","server_name":"srv1"}
getting-started-caddy-1 | {"level":"info","ts":1690876430.9071064,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x40001fb420"}
getting-started-caddy-1 | {"level":"info","ts":1690876430.907149,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
getting-started-caddy-1 | {"level":"info","ts":1690876430.907417,"logger":"tls","msg":"finished cleaning storage units"}
getting-started-caddy-1 | {"level":"debug","ts":1690876430.9074674,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
getting-started-caddy-1 | {"level":"info","ts":1690876430.9074967,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
getting-started-caddy-1 | {"level":"debug","ts":1690876430.9078667,"logger":"http","msg":"starting server loop","address":"[::]:8080","tls":false,"http3":false}
getting-started-caddy-1 | {"level":"info","ts":1690876430.9080462,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
getting-started-caddy-1 | {"level":"info","ts":1690876430.9084826,"msg":"autosaved config (
From our gRPC client:
2023/08/01 10:05:50 INFO: [transport] [client-transport 0x140000a6b40] Closing: connection error: desc = "error reading server preface: http2: frame too large"
2023/08/01 10:05:50 INFO: [core] Creating new client transport to "{\n \"Addr\": \"192.168.65.1:80\",\n \"ServerName\": \"192.168.65.1:80\",\n \"Attributes\": null,\n \"BalancerAttributes\": null,\n \"Type\": 0,\n \"Metadata\": null\n}": connection error: desc = "error reading server preface: http2: frame too large"
2023/08/01 10:05:50 WARNING: [core] [Channel #1 SubChannel #2] grpc: addrConn.createTransport failed to connect to {
"Addr": "192.168.65.1:80",
"ServerName": "192.168.65.1:80",
"Attributes": null,
"BalancerAttributes": null,
"Type": 0,
"Metadata": null
}. Err: connection error: desc = "error reading server preface: http2: frame too large"
v2.6.4
Running a local docker container on Docker for desktop on MacOS
docker-compose up -d
version: "3.4"
# Caddy reverse proxy
image: caddy
networks: [ netbird ]
- '443:443'
- '80:80'
- '8080:8080'
- netbird_caddy_data:/data
netbird_caddy_data:
netbird:
So far I’ve tested with auto_https off and without setting it, I’ve also used http://192.168.65.1:80 and http://192.168.65.1:8080 for site addresses without luck either.
auto_https off
servers :80,:8080 {
protocols h1 h2c
:80, :8080 {
# Signal
reverse_proxy /signalexchange.SignalExchange/* h2c://signal:10000
# Management
reverse_proxy /api/* management:80
reverse_proxy /management.ManagementService/* h2c://management:80
# Zitadel
reverse_proxy /zitadel.admin.v1.AdminService/* h2c://zitadel:8080
reverse_proxy /admin/v1/* h2c://zitadel:8080
reverse_proxy /zitadel.auth.v1.AuthService/* h2c://zitadel:8080
reverse_proxy /auth/v1/* h2c://zitadel:8080
reverse_proxy /zitadel.management.v1.ManagementService/* h2c://zitadel:8080
reverse_proxy /management/v1/* h2c://zitadel:8080
reverse_proxy /zitadel.system.v1.SystemService/* h2c://zitadel:8080
reverse_proxy /system/v1/* h2c://zitadel:8080
reverse_proxy /assets/v1/* h2c://zitadel:8080
reverse_proxy /ui/* h2c://zitadel:8080
reverse_proxy /oidc/v1/* h2c://zitadel:8080
reverse_proxy /saml/v2/* h2c://zitadel:8080
reverse_proxy /oauth/v2/* h2c://zitadel:8080
reverse_proxy /.well-known/openid-configuration h2c://zitadel:8080
reverse_proxy /openapi/* h2c://zitadel:8080
reverse_proxy /debug/* h2c://zitadel:8080
# Dashboard
reverse_proxy /* dashboard:80
