Issues with nested subdomains
I have a setup where nested subdomains are required but caddy does not seem to support them. I am trying to “catch” them using :443.
*   Trying <ip>:443...
* Connected to one.two.example.com (<ip>) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*  CApath: /etc/ssl/certs
* TLSv1.0 (IN), TLS header, Unknown (21):
* TLSv1.3 (IN), TLS alert, handshake failure (552):
* error:0A000410:SSL routines::sslv3 alert handshake failure
* Closing connection 0
curl: (35) error:0A000410:SSL routines::sslv3 alert handshake failure
Despite debug being enabled i did not get any logs using the :443 setup.
The browser throwed SSL_ERROR_NO_CYPHER_OVERLAP.
I later tried hardcoding the nested subdomain and it throwed this:
caddy Error: adapting config using caddyfile: ambiguous site definition: sub.sub.example.com
I used docker
Ubuntu 24.04.1 LTS
Docker version 27.5.1
sudo docker compose up -d
    image: caddy:latest
      - ./caddy/data:/data
      - ./caddy/config:/config
      - web
    restart: always
    email my-email@example.com
    on_demand_tls {
        ask http://example.com
:443 {
        on_demand
    reverse_proxy app:3011
It does
Show us the config you tried that produced these errors.
    on_demand_tls {
sub.sub.example.com {
        on_demand
    reverse_proxy app:3010
:443 {
        on_demand
First, let’s take a step back. The error SSL_ERROR_NO_CYPHER_OVERLAP is not about the site definition in Caddy. Your browser does not seem to support proper, modern TLS cipher suites. This is the default cipher suite in Caddy:
  • TLS_AES_128_GCM_SHA256
  • TLS_CHACHA20_POLY1305_SHA256
  • TLS_AES_256_GCM_SHA384
  • TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
  • TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
  • TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
  • TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
  • TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256
  • TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256
  • TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA
  • TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA
  • TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA
  • TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA
  • TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA
Check why your browser isn’t supporting them.
For sub-sub-domain definition, or any level for that matter, something like this should be enough:
You don’t need on_demand or anything like that, that is unless the real config file has other unshared config.
