v2.5.1
Opnsense vm redirecting trafic from 80 and 443 to Caddy vm.
Proxmox Lxc container running caddy.
Caddy is run in a docker container and managed with docker-compose.
|Distributor ID:|Debian|
|Description:|Debian GNU/Linux 11 (bullseye)|
|Release:|11|
|Codename:|bullseye|
Client: Docker Engine - Community
Version: 20.10.17
API version: 1.41
Go version: go1.17.11
Git commit: 100c701
Built: Mon Jun 6 23:03:17 2022
OS/Arch: linux/amd64
Context: default
Experimental: true
Server: Docker Engine - Community
Engine:
Version: 20.10.17
API version: 1.41 (minimum version 1.12)
Git commit: a89b842
Built: Mon Jun 6 23:01:23 2022
Experimental: false
containerd:
Version: 1.6.6
GitCommit: 10c12954828e7c7c9b6e0ea9b0c02b01407d3ae1
runc:
Version: 1.1.2
GitCommit: v1.1.2-0-ga916309
docker-init:
Version: 0.19.0
GitCommit: de40ad0
No command is run because the docker container starts it.
Docker-compose content:
<<: *std-keys-sec-be
build:
context: $DOCKER_DIR/caddy
dockerfile: dockerfile
image: caddy:cloudflare
- 443:443
- CLOUDFLARE_API_TOKEN=$CF_TOKEN
- $DOCKER_DIR/caddy/Caddyfile:/etc/caddy/Caddyfile:ro
- $DOCKER_DIR/caddy/data:/data
- $DOCKER_DIR/caddy/config:/config
- $LOG_DIR/caddy:/opt/logs/caddy
email me@xs.me
(trusted_proxies_list) {
trusted_proxies 172.16.0.0/16 192.168.0.0/16 fc00::/7 100.64.0.0/10
auth.xs.me authelia.xs.me {
reverse_proxy authelia:9091 {
import trusted_proxies_list
*.xs.me {
level INFO
output file /opt/logs/caddy/caddy.log {
roll_size 10MB
roll_keep 10
dns cloudflare {$CLOUDFLARE_API_TOKEN}
forward_auth authelia:9091 {
uri /api/verify?rd=https://auth.xs.me
copy_headers Remote-User Remote-Groups Remote-Name Remote-Email
@pmx-tfk-tc host tfk-tc.xs.me
reverse_proxy @pmx-tfk-tc cloudcmd:8000
Running this configuration on a desktop works without any issues. The same configuration used with a mobile phone does not pass the authentication step.
Redirection to authelia is working fine. I get my authelia credentials request but the password is refused.
Getting error message “Incorrect Username or Password”.
This is the returned URL from Caddy:
https://auth.xs.me/?rd=https%3A%2F%2Ftfk-tc.xs.me%2F&rm=GET,%20https://auth.xs.me/?rd=https://tfk-tc.xs.me/,GET
I am not saying Caddy is the problem but coming from Traefik with the same config on Authelia side did not raised this error.
“Incorrect Username or Password” when entering credentials on the Authelia form.
Checked Caddy forum
Checked Authelia forum
Disabled all ad-blocking addons
Reduced browser security
Tried different browser
Tried to authenticate directly to Authelia by typing auth.xs.me. Credentials are accepted and I can thereafter access the protected site!
