Issues w/ handle_errors and reverse_proxy again
1. Caddy version:
Built from master a few minutes ago: v2.2.2-0.20201118231455-12cc69ab7ade h1:Pss1c1toELBy8jbzQGQpD327MkPLS+4XfWptLzjkQQM=
My normal setup is currently on: v2.2.1 h1:Q62GWHMtztnvyRU+KPOpw6fNfeCD3SkwH7SfT1Tgt2c=
My normal setup involves docker and such, but this example is just using xcaddy to build from master, running caddy with ./caddy run, and accessing the webserver via 192.168.1.101:9090 from another machine on LAN.
$ uname -a
Linux xnaasSRV 4.19.0-12-amd64 #1 SMP Debian 4.19.152-1 (2020-10-18) x86_64 GNU/Linux
Again: normally this is all dockerized and such, which is where I first noticed the issue. But I’ve build from master and am running more “normally” for this testing to demonstrate that the issue is not my specific setup.
./caddy run
N/A # Not relevant at this time
:9090 {
  root ./test/
  handle_errors {
    rewrite * /{http.error.status_code}
    reverse_proxy https://http.cat
  file_server browse
This setup is not working as it used to. A normal workflow previously:
  1. Go to 192.168.1.101:9090
  2. Everything works fine
  3. Go to 192.168.1.101:9090/nothere
  4. Get https://http.cat/404 displayed from reverse_proxy
Unfortunately, now something is doing something janky. Instead, I end up getting sent in a redirect loop that causes every major browser to error out. It seems like it’s trying to point me to 192.168.1.101:9090/private/?r=<spamhere> and/or 192.168.1.101:9090/404?r=<spamhere>.
Here’s an example from debug logging when trying to go to 192.168.1.101:9090/nothere: https://pastebin.com/gVafzx41 (the bit at the end is just me hitting ctrl+c to kill the process).
Other than removing the handle_errors, I can’t think of what to try, thus I’ve come here seeking assistance.
I first noticed this issue…maybe within the last week or two? It’s possible something changed on http.cat’s end. I don’t really know how to diagnose that, though.
Hadn’t we determined that you need to use header_up Host http.cat as a reverse_proxy subdirective? Maybe I’m thinking of a different thread.
What happens when you make the request with curl -v? That should show the headers in the request, it’s easier to follow. You can use curl -vL to follow the redirects.
I don’t know anything about it, but I can definitely add a header now if that’s needed.
Without adding any header: https://pastebin.com/KpnuFBRF
Edit: with that header added, everything appears to be good now. :+1:t2:
Edit 2: and thanks a ton. :slight_smile:
Hah, yep, it was someone else doing the exact same thing:
Damn, I even tried searching first too. :weary: Thanks again. :smile:
