Issues using Caddy to Proxy to Guacamole
Hi everyone,
I originally had an Apache2 server that I was using as a proxy to various internal sites. That server was being decommissioned, and I decided to use Caddy this time around. 5 out of 6 HTTPS sites are working perfectly, but I’m having issues with Guacamole. The page loads, and I am able to log in, but once I attempt to start an RDP, VNC, or SSH connection, it disconnects almost immediately.
On the original proxy server (apache2) the virtual host config was as follows:
<VirtualHost *:443>
    ServerName remote.example.com
    # SSL Config
    SSLEngine On
    SSLProxyEngine On
    SSLProxyVerify none
    SSLProxyCheckPeerCN off
    SSLProxyCheckPeerName off
    SSLProxyCheckPeerExpire off
    # Proxy
    ProxyPreserveHost On
    ProxyPass / https://10.0.50.149:443/ flushpackets=on
    ProxyPassReverse / https://10.0.50.149:443/
    # Certs
    SSLCertificateFile /etc/letsencrypt/live/remote.example.com/cert.pem
    SSLCertificateKeyFile /etc/letsencrypt/live/remote.example.com/privkey.pem
    SSLCertificateChainFile /etc/letsencrypt/live/remote.example.com/chain.pem
</VirtualHost>
On the new Caddy server, the caddyfile contains:
https://remote.example.com {
	import common.conf
	proxy / https://10.0.50.149:443 {
		insecure_skip_verify
Here is the contents of the “common.conf” file:
gzip
ipfilter / {
	rule allow
	ip 10.0.50.0/24
	ip 10.0.20.0/24
	country CA US
	database /opt/caddy/GeoLite2/GeoLite2-Country.mmdb
	blockpage  /var/www/static/access_denied.html
I tried adding a few different options nested under proxy, with no success:
header_upstream Host {host}
header_downstream X-Real-IP {remote}
header_downstream Host {host}
I was wondering if anyone can offer any insight as to what might be different between the apache and caddy configs. One thing I can’t seem to find any information on is the “flushpackets=on” parameter.
Thanks
I think Guacamole wants a websocket. Try:
		websocket
Hi, thanks for the suggestion, but it didn’t work. I even pointed the the caddyfile to the original port advertised by Tomcat (8080):
https://remote.badin.network {
        import common.conf
        proxy / http://10.0.50.149:8080/guacamole/ {
                websocket
After some further digging, I found the manual for Guacamole.It looks like for Apache, the "proxypass" needs to have the following option turned on:
flushpackets=on
For Nginx, the equivalent appears to be:
proxy_buffering off
Does Caddy have anything like this?
Hmm. Definitely doesn’t need it. I’ve just written up and deployed a Guacamole instance, here are my configs:
→ cat docker-compose.yml
version: '2.1'
  guacdb:
    image: mariadb:10
      # docker run --rm guacamole/guacamole /opt/guacamole/bin/initdb.sh --mysql > initdb.sql
      - ./initdb.sql:/docker-entrypoint-initdb.d/initdb.sql
      - ./guacdb:/var/lib/mysql
      # `date | md5sum`
      MYSQL_ROOT_PASSWORD: 16ce20fc37d15a4f272074967c0c3002
      MYSQL_DATABASE: guac
      MYSQL_USER: guac
      # `date | md5sum`
      MYSQL_PASSWORD: 54e0ba1cb2b4f643ab2fae94433e046e
    restart: always
  guacd:
    image: guacamole/guacd
    depends_on:
      - guacdb
    restart: always
  guacamole:
    image: guacamole/guacamole
    depends_on:
      - guacd
      - guacdb
      MYSQL_USER: guac
      # `date | md5sum`
      GUACD_HOSTNAME: guacd
      MYSQL_HOSTNAME: guacdb
    restart: always
# web_default belongs to a docker-composed Caddy instance, for ease of proxying:
  default:
    external:
→ cat Caddyfile
import /etc/vhosts/*.caddy
→ cat guacamole.whitestrake.net.caddy
guacamole.whitestrake.net {
    rewrite / /guacamole
    proxy /guacamole guacamole:8080 {
        websocket
Site is available at https://guacamole.whitestrake.net (for the time being).
I have tested an RDP session to a Windows 2012 r2 server, I was able to keep the connection open for at least 15 minutes before I logged off as I definitely don’t seem to have the same issue as you’re describing.
Only thing I can think of is that I handle the path (/guacamole) a little differently than you do.
To answer this one - no, I don’t believe it does have a setting for this. But I don’t think Caddy suffers from the issue described by the Guacamole manual to begin with, as demonstrated by my above example.
Thanks for taking the time to get all of that set up, I really appreciate it. I tried modifying my caddy file to match yours:
        import common.conf
        proxy / http://10.0.50.149:8080 {
                websocket
However, I get the same result. At this point, it looks like the problem may be how my Guacamole instance is set up. I’ll rebuild it from scratch and report back.
I’ve built my new Guacamole VM (CentOS7). I am using Guacamole version 0.9.12. Guacamole is available and working on port 8080. On my proxy server, I’m using the following caddyfile:
        import common.conf
        proxy / http://10.0.50.15:8080 {
                websocket
When I connect directly to the Guacamole server, on port 8080, I am able to use RDP without any disconnections. However, once I use the proxy server to access Guacamole, the connection times out after 5-15 seconds.
Add timeouts none to your Caddyfile; this won’t be needed after the next release.
Thanks Matt, that fixed it.
Huh. Just double checked the version of Caddy running in my containers. It’s 0.9.3, which explains why I don’t need that…
Maybe I’ll wait until next release to update them, seems to be running just fine in the meantime. :slight_smile:
