Issues setting up ntfy with Matrix
I’ve been running matrix and wanted to enhance its capability with ntfy.sh. I run Caddy as rootless revproxy for my docker host but so far ntfy has been causing me the biggest headaches because Caddy doesn’t seem to want to resolve the container-name, whereas it does it for all the other services without fail. I’m not sure where to go from here
{"level":"error","ts":1701742697.6973655,"logger":"http.log.error","msg":"dial tcp: lookup matrix-ntfy on 127.0.0.11:53: no such host","request":{"remote_ip":"194.x.x.x","remote_port":"19978","proto":"HTTP/1.1","method":"GET","host":"ntfy.domain.tld","uri":"/upeF3xoBFLDsPD/ws?since=none","headers":{"Accept-Encoding":["gzip"],"User-Agent":["ntfy/1.16.0 (fdroid; Android 14; SDK 34)"],"Upgrade":["websocket"],"Sec-Websocket-Key":["kW8bSKbZq/NI1lvsdMOW4w=="],"Sec-Websocket-Extensions":["permessage-deflate"],"Connection":["Upgrade"],"Sec-Websocket-Version":["13"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"http/1.1","server_name":"ntfy.domain.tld"}},"duration":0.001157049,"status":502,"err_id":"f60q9gy9b","err_trace":"reverseproxy.statusError (reverseproxy.go:1299)"}
    image: caddy:2-alpine
    container_name: matrix-caddy
    read_only: true
    user: 1000:1000
    depends_on:
      - ntfy
      - element
      - synapse
      - element
      - synapse
      - ntfy
      - "8448:8448"
      - ./configs/caddy/Caddyfile:/etc/caddy/Caddyfile
      - matrix_caddy_data:/data
Alpine Linux 3.18
Docker version 23.0.6, build ef23cbc4315ae76c744e02d687c09548ede461bd
  ntfy:
    image: binwiederhier/ntfy:latest
    container_name: matrix-ntfy
    read_only: true
      - ntfy
    command:
      - serve
      NTFY_BASE_URL: http://ntfy.domain.tld
      NTFY_CACHE_FILE: /var/lib/ntfy/cache.db
      NTFY_BEHIND_PROXY: true
      NTFY_LISTEN_HTTP: ":2586"
      NTFY_LOG_LEVEL: debug
    user: 1000:1000
    tmpfs:
      - /var/lib/ntfy
    healthcheck:
        test: ["CMD-SHELL", "wget -q --tries=1 http://localhost:2586/v1/health -O - | grep -Eo '\"healthy\"\\s*:\\s*true' || exit 1"]
        interval: 60s
        timeout: 10s
        retries: 3
        start_period: 40s
https://domain.tld {
  header /.well-known/matrix/* Content-Type application/json
  header /.well-known/matrix/* Access-Control-Allow-Origin *
  respond /.well-known/matrix/client "{ \"m.homeserver\": {\"base_url\": \"https://domain.tld\" }, \"org.matrix.msc3575.proxy\": {\"url\": \"https://syncv3.domain.tld\" } }"
  respond /.well-known/matrix/server "{ \"m.server\": {\"base_url\": \"https://domain.tld:8448\" }"
  #doesn't work
  #reverse_proxy /_matrix/client/unstable/org.matrix.msc3575/sync matrix-sliding-sync:8888
  #reverse_proxy /client/* matrix-sliding-sync:8888
  reverse_proxy /_matrix/* matrix-synapse:8008
  reverse_proxy /_synapse/client/* matrix-synapse:8008
  redir / https://element.domain.tld
https://matrix.domain.tld {
  reverse_proxy /_matrix/* localhost:8008
  reverse_proxy /_synapse/client/* localhost:8008
https://element.domain.tld {
  encode zstd gzip
  reverse_proxy matrix-element:80
    Referrer-Policy  strict-origin-when-cross-origin
    Strict-Transport-Security "max-age=63072000; includeSubDomains;"
    Permissions-Policy "accelerometer=(), camera=(), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), payment=(), usb=(), interest-cohort=()"
    X-Frame-Options SAMEORIGIN
    X-XSS-Protection 1
    X-Robots-Tag none
    -server
ntfy.domain.tld, http://ntfy.domain.tld, https://ntfy.domain.tld {
    reverse_proxy matrix-ntfy:2586
    @httpget {
        protocol http
        method GET
        path_regexp ^/([-_a-z0-9]{0,64}$|docs/|static/)
    redir @httpget https://{host}{uri}
Try simply ntfy (the service name) instead of matrix-ntfy (the container name)
Either way, this is a Docker problem, not a Caddy problem.
Docker’s DNS resolver is the problem. I can’t see at a glance what the problem is, but I’m not an expert so I’m not sure what to recommend.
