I was able to manually deploy Caddy in front of my Docker swarm and got it working without too much issue with the following Caddyfile
app.hostname.com {
proxy / http://appname:3000
load /run/secrets/
I’m feeding the cert/key pem files in with Docker Secrets and it picks them up and started just fine. However, if I build my own Docker image and include a more permanent and flexible Caddyfile:
{$HOSTNAME} {
load /run/secrets/
it doesn’t work. The log output indicates that it’s picking up the $HOSTNAME variable I’m passing in and shows the following:
Serving HTTPS on port 2015
https://app.hostname.com:2015
2019/03/18 20:54:06 [INFO] Serving https://app.hostname.com:2015
2019/03/18 20:54:06 [INFO][FileStorage:/root/.caddy] Started certificate maintenance routine
It’s as if it’s completely ignoring serving on 443/80. If I try hitting https://app.hostname.com:2015 nothing comes back. Any insight would be a life saver at this point. Thanks!
