systemd
Ubuntu 18.04
n/a
/na
"apps": {
"http": {
"servers": {
"srv0": {
"automatic_https": {
"disable": true
"listen": [
":80"
"routes": [
"handle": [
"handler": "subroute",
"routes": [
"group": "group0",
"handle": [
"handler": "vars",
"root": "/opt/ivt/photography"
"match": [
"path": [
"/files/*"
"group": "group0",
"handle": [
"handler": "vars",
"root": "/opt/ivt/apps/6.0.0/packages/client/spa"
"handle": [
"routes": [
"handle": [
"handler": "rewrite",
"uri_substring": [
"find": "/console_socket",
"replace": "/console/socket.io"
"handle": [
"handler": "reverse_proxy",
"headers": {
"request": {
"set": {
"Access-Control-Allow-Credentials": [
"true"
"Access-Control-Allow-Headers": [
"Cache-Control,Content-Type"
"Access-Control-Allow-Origin": [
"X-Forwarded-Proto": [
"{http.request.scheme}"
"X-Real-Ip": [
"{http.request.remote.host}"
"upstreams": [
"dial": "localhost:3001"
"match": [
"path": [
"/console_socket/*"
"handle": [
"routes": [
"handle": [
"uri_substring": [
"find": "/web_app_socket",
"replace": "/web/socket.io"
"handle": [
"headers": {
"request": {
"set": {
"true"
"X-Real-Ip": [
"upstreams": [
"match": [
"path": [
"/web_app_socket/*"
"handle": [
"routes": [
"handle": [
"uri_substring": [
"find": "/liveview",
"replace": "/socket.io"
"handle": [
"headers": {
"request": {
"set": {
"true"
"X-Real-Ip": [
"upstreams": [
"dial": "localhost:3004"
"match": [
"path": [
"/liveview/*"
"handle": [
"routes": [
"handle": [
"uri_substring": [
"find": "/weather",
"handle": [
"headers": {
"request": {
"set": {
"true"
"X-Real-Ip": [
"upstreams": [
"dial": "localhost:3010"
"match": [
"path": [
"/weather/*"
"handle": [
"routes": [
"handle": [
"uri_substring": [
"find": "/archive",
"handle": [
"headers": {
"request": {
"set": {
"true"
"X-Real-Ip": [
"upstreams": [
"dial": "localhost:3003"
"match": [
"path": [
"/archive/*"
"handle": [
"routes": [
"handle": [
"uri_substring": [
"find": "/alarms",
"handle": [
"headers": {
"request": {
"set": {
"true"
"X-Real-Ip": [
"upstreams": [
"dial": "localhost:3002"
"match": [
"path": [
"/alarms/*"
"handle": [
"routes": [
"handle": [
"uri_substring": [
"find": "/ptz",
"handle": [
"headers": {
"request": {
"set": {
"true"
"X-Real-Ip": [
"upstreams": [
"dial": "localhost:3006"
"match": [
"path": [
"/ptz/*"
"handle": [
"routes": [
"handle": [
"headers": {
"request": {
"set": {
"true"
"X-Real-Ip": [
"upstreams": [
"match": [
"path": [
"/api/*"
"handle": [
"handler": "file_server",
"hide": [
"Caddyfile"
"match": [
"host": [
"localhost"
"terminal": true
"tls": {
"automation": {
"policies": [
"issuer": {
"module": "internal"
"logging": {
"logs": {
"default": {
"level": "DEBUG"
I am programmatically adding reverse_proxies to the json and sending the whole file using the load end-point.
What I am seeing, is if the command is repeated, then instead of 4 proxies being added, it befomes 8. The next time it is 12. It’s as if Caddy is merging what I send, instead of starting “fresh”.
If I sent the default json, with no added proxies, then the currently added proxies remain.
if I run this after a reset I can see the proxies remain:
curl localhost:2019/config/ | grep dcam-dev
I have tried playing around with caching to see if that changes anything, but none work:
‘Cache-Control’: ‘must-revalidate’
‘Cache-Control’: ‘no-store’
‘Cache-Control’: ‘no-cache’
What this do tho, was force caddy into not thinking the cache had changed.
Before adding ‘Cache-Control’ command, I was getting this:
Aug 21 09:26:16 FLEX-5 caddy[1037]: {"level":"info","ts":1598023576.419586,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_addr":"127.0.0.1:54164","headers":{"Accept":["application/json, text/plain, */*"],"Connection":["close"],"Content-Length":["9050"],"Content-Type":["application/json"],"User-Agent":["axios/0.19.2"]}}
Aug 21 09:26:16 FLEX-5 caddy[1037]: {"level":"info","ts":1598023576.4207368,"logger":"admin.api","msg":"config is unchanged"}
Aug 21 09:26:16 FLEX-5 caddy[1037]: {"level":"info","ts":1598023576.4207559,"logger":"admin.api","msg":"load complete"}
But with the cache command, I now get this:
Aug 21 10:30:15 FLEX-5 caddy[1037]: {"level":"info","ts":1598027415.6441956,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_addr":"127.0.0.1:59392","headers":{"Accept":["application/json, text/plain, */*"],"Cache-Control":["must-revalidate"],"Connection":["close"],"Content-Length":["6868"],"Content-Type":["application/json"],"User-Agent":["axios/0.19.2"]}}
Aug 21 10:30:15 FLEX-5 caddy[1037]: {"level":"info","ts":1598027415.64678,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
Aug 21 10:30:15 FLEX-5 caddy[1037]: 2020/08/21 10:30:15 [INFO][cache:0xc000de3440] Started certificate maintenance routine
Aug 21 10:30:15 FLEX-5 caddy[1037]: {"level":"debug","ts":1598027415.6508875,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
Aug 21 10:30:15 FLEX-5 caddy[1037]: {"level":"warn","ts":1598027415.6512709,"logger":"pki.ca.local","msg":"installing root certificate (you might be prompted for password)","path":"storage:pki/authorities/local/root.crt"}
Aug 21 10:30:15 FLEX-5 caddy[1037]: 2020/08/21 10:30:15 not NSS security databases found
Aug 21 10:30:15 FLEX-5 caddy[1037]: 2020/08/21 10:30:15 define JAVA_HOME environment variable to use the Java trust
Aug 21 10:30:15 FLEX-5 sudo[4692]: pam_unix(sudo:auth): conversation failed
Aug 21 10:30:15 FLEX-5 sudo[4692]: pam_unix(sudo:auth): auth could not identify password for [caddy]
Aug 21 10:30:15 FLEX-5 caddy[1037]: {"level":"error","ts":1598027415.655627,"logger":"pki.ca.local","msg":"failed to install root certificate","error":"failed to execute sudo: exit status 1","certificate_file":"storage:pki/authorities/local/root.crt"}
Aug 21 10:30:15 FLEX-5 caddy[1037]: 2020/08/21 10:30:15 [INFO][cache:0xc000ca4240] Stopped certificate maintenance routine
Aug 21 10:30:15 FLEX-5 caddy[1037]: {"level":"info","ts":1598027415.6559749,"msg":"autosaved config","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Aug 21 10:30:15 FLEX-5 caddy[1037]: {"level":"info","ts":1598027415.655991,"logger":"admin.api","msg":"load complete"}
Aug 21 10:30:16 FLEX-5 caddy[1037]: {"level":"info","ts":1598027416.1492498,"logger":"admin","msg":"stopped previous server"}
But, the contents of Caddy are unchanged when I do this:
or, the data is merged in some way (unexpected)
After adjusting our default caddy json file, I send it with axios like this:
function putConfig (config) {
return new Promise((resolve, reject) => {
axios({
method: 'post',
url: 'http://localhost:2019/load',
headers: {
'Content-Type': 'application/json',
'Cache-Control': 'must-revalidate'
data: config
.then(results => {
console.log(results)
resolve(results.data)
.catch(error => {
console.log(error)
reject(error.message)
response back is 200
