$caddy version
I run caddy in my home network, from a local computer with local ip 192.168.1.100.
I have a domain name (my_domain.com below) that is linked to my public ip.
Both ports 443 and 80 are forwarded to 192.168.1.100 on my router.
Debian 11.
No docker
$ cd folder_with_Caddyfile
$ caddy run
NA
https://my_domain.com, http://my_domain.com {
respond "Hello, world!"
- http access seems fine from a computer on the same LAN:
$ curl http://my_domain.com
Hello, world
- https access doesn’t work from a computer on the same LAN:
$ curl -v https://my_domain.com
* Trying my_public_ip:443...
* Connected to my_domain.com (my_public_ip) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CAfile: /home/jonolo/anaconda3/ssl/cacert.pem
* CApath: none
* error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error
* Closing connection 0
$ caddy run
2021/11/16 12:34:02.476 INFO using adjacent Caddyfile
2021/11/16 12:34:02.477 WARN input is not formatted with 'caddy fmt' {"adapter": "caddyfile", "file": "Caddyfile", "line": 2}
2021/11/16 12:34:02.477 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["127.0.0.1:2019", "localhost:2019", "[::1]:2019"]}
2021/11/16 12:34:02.478 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2021/11/16 12:34:02.478 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2021/11/16 12:34:02.478 INFO http server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server {"server_name": "srv1", "http_port": 80}
2021/11/16 12:34:02.478 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc000377b20"}
2021/11/16 12:34:02.478 INFO tls cleaning storage unit {"description": "FileStorage:/root/.local/share/caddy"}
2021/11/16 12:34:02.478 INFO http enabling automatic TLS certificate management {"domains": ["my_domain.com"]}
2021/11/16 12:34:02.479 INFO autosaved config (load with --resume flag) {"file": "/root/.config/caddy/autosave.json"}
2021/11/16 12:34:02.479 INFO serving initial configuration
2021/11/16 12:34:02.479 INFO tls finished cleaning storage units
2021/11/16 12:34:02.479 INFO tls.obtain acquiring lock {"identifier": "my_domain.com"}
2021/11/16 12:34:02.510 INFO tls.obtain lock acquired {"identifier": "my_domain.com"}
2021/11/16 12:34:02.512 INFO tls.issuance.acme waiting on internal rate limiter {"identifiers": ["my_domain.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2021/11/16 12:34:02.512 INFO tls.issuance.acme done waiting on internal rate limiter {"identifiers": ["my_domain.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2021/11/16 12:34:03.994 INFO tls.issuance.acme.acme_client trying to solve challenge {"identifier": "my_domain.com", "challenge_type": "http-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2021/11/16 12:34:15.054 ERROR tls.issuance.acme.acme_client challenge failed {"identifier": "my_domain.com", "challenge_type": "http-01", "problem": {"type": "urn:ietf:params:acme:error:connection", "title": "", "detail": "Fetching http://my_domain.com/.well-known/acme-challenge/3n5RaavT_vgwrZjy0pcTZfSykpJ_QsyEGJ64R_m_1U0: Timeout during connect (likely firewall problem)", "instance": "", "subproblems": []}}
2021/11/16 12:34:15.054 ERROR tls.issuance.acme.acme_client validating authorization {"identifier": "my_domain.com", "problem": {"type": "urn:ietf:params:acme:error:connection", "title": "", "detail": "Fetching http://my_domain.com/.well-known/acme-challenge/3n5RaavT_vgwrZjy0pcTZfSykpJ_QsyEGJ64R_m_1U0: Timeout during connect (likely firewall problem)", "instance": "", "subproblems": []}, "order": "https://acme-v02.api.letsencrypt.org/acme/order/281589040/40108454990", "attempt": 1, "max_attempts": 3}
2021/11/16 12:34:16.306 ERROR tls.obtain could not get certificate from issuer {"identifier": "my_domain.com", "issuer": "acme-v02.api.letsencrypt.org-directory", "error": "HTTP 429 urn:ietf:params:acme:error:rateLimited - Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/"}
2021/11/16 12:34:16.307 WARN tls.issuance.zerossl missing email address for ZeroSSL; it is strongly recommended to set one for next time
2021/11/16 12:34:17.653 INFO tls.issuance.zerossl generated EAB credentials {"key_id": "IAE1ZIMYjo4uLCcaG7Ngeg"}
2021/11/16 12:34:19.541 INFO tls.issuance.acme waiting on internal rate limiter {"identifiers": ["my_domain.com"], "ca": "https://acme.zerossl.com/v2/DV90", "account": ""}
2021/11/16 12:34:19.541 INFO tls.issuance.acme done waiting on internal rate limiter {"identifiers": ["my_domain.com"], "ca": "https://acme.zerossl.com/v2/DV90", "account": ""}
2021/11/16 12:34:20.231 INFO tls.issuance.acme.acme_client trying to solve challenge {"identifier": "my_domain.com", "challenge_type": "http-01", "ca": "https://acme.zerossl.com/v2/DV90"}
2021/11/16 12:39:22.015 ERROR tls.obtain could not get certificate from issuer {"identifier": "my_domain.com", "issuer": "acme.zerossl.com-v2-DV90", "error": "[my_domain.com] solving challenges: [my_domain.com] authorization took too long (order=https://acme.zerossl.com/v2/DV90/order/0Tf9y6_XybNx-K7erM-nRQ) (ca=https://acme.zerossl.com/v2/DV90)"}
2021/11/16 12:39:22.015 ERROR tls.obtain will retry {"error": "[my_domain.com] Obtain: [my_domain.com] solving challenges: [my_domain.com] authorization took too long (order=https://acme.zerossl.com/v2/DV90/order/0Tf9y6_XybNx-K7erM-nRQ) (ca=https://acme.zerossl.com/v2/DV90)", "attempt": 1, "retrying_in": 60, "elapsed": 319.505131193, "max_duration": 2592000}
- Check that DNS is set properly:
curl "https://cloudflare-dns.com/dns-query?name=my_domain.com&type=A" \
-H "accept: application/dns-json"
{"Status":0,"TC":false,"RD":true,"RA":true,"AD":false,"CD":false,"Question":[{"name":"my_domain.com","type":1}],"Answer":[{"name":"my_domain.com","type":1,"TTL":3600,"data":"my_public_ip"}]}%
my_domain.com is linked to my_public_ip, I think everything looks fine here.
- My ISP was blocking 80 and 443 ports by default. I ‘unblocked’ these from their portal a few days ago. However both http and https access don’t work from the outside, I’m not sure if this issue is related.
# From remote machine
curl: (28) Failed to connect to my_domain.com.au port 80: Operation timed out
curl https://my_domain.com
curl: (7) Failed to connect to my_domain.com port 443: Operation timed out
