1. Output of caddy version
System is Ubuntu 22.04 LTS
Docker is being used with the official caddy docker image.
docker-compose up -d --build caddy
example.com {
reverse_proxy app:5000
mail.example.com {
tls email@domain.tld
root * /var/www/html
I am trying to host a static html file using Caddy on my subdomain mail.example.com
. Issue that I receive is that it shows the following:
root@localhost:~# curl -v mail.example.com
* Trying ip:80...
* Connected to mail.example.com (ip) port 80 (#0)
> GET / HTTP/1.1
> Host: mail.example.com
> User-Agent: curl/7.81.0
< Connection: close
< Location: https://mail.example.com/
< Server: Caddy
< Date: Wed, 11 Jan 2023 14:25:14 GMT
< Content-Length: 0
* Closing connection 0
version: "3"
image: caddy:2
- "443:443/udp"
depends_on:
- app
links:
- app
- ./site:/srv
- ./data:/data
- ./config:/confi
I have tried to change around my DNS records to see if it was an issue in there, but didn’t appear to be an issue. I then moved onto looking at the Caddy logs from docker which shows the following:
{"level":"debug","ts":1673447450.0405607,"logger":"http.log.error","msg":"{id=nz45wcygd} fileserver.(*FileServer).notFound (staticfiles.go:579): HTTP 404","request":{"remote_ip":"58.174.118.197","remote_port":"50604","proto":"HTTP/3.0","method":"GET","host":"mail.example.com","uri":"/","headers":{"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Ch-Ua":["\"Not?A_Brand\";v=\"8\", \"Chromium\";v=\"108\", \"Brave\";v=\"108\""],"Sec-Ch-Ua-Mobile":["?0"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36"],"Accept-Language":["en-GB,en;q=0.9"],"Sec-Fetch-Site":["none"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Dest":["document"],"Sec-Ch-Ua-Platform":["\"macOS\""],"Upgrade-Insecure-Requests":["1"],"Sec-Gpc":["1"]},"tls":{"resumed":false,"version":0,"cipher_suite":0,"proto":"","server_name":""}},"duration":0.000996067,"status":404,"err_id":"nz45wcygd","err_trace":"fileserver.(*FileServer).notFound (staticfiles.go:579)"}
This is the error that sent me here, as I don’t understand how to fix it. I have the index.html
file saved at /var/www/html/index.html
so it doesn’t make much sense t ome why it can’t locate that or a fil
