I’m trying to use the global order on the directives so that maxmind_geolocation is called first, then crowdsec, then authelia, but I think I’m using the wrong name to call maxmind_geolocation.
Using the custom caddy build, serfriz/caddy-crowdsec-geoip, which uses the modules porech/caddy-maxmind-geolocation and hslatman/caddy-crowdsec-bouncer to secure a reverse proxy with my domain. Authelia is used as well.
Everything seems to be working when setting crowdsec first and not messing with the maxmind_geolocation order. I can authenticate through authelia, then login to the service, and if my ip is in a blocked country, it gives a blank screen. Think it makes more sense to block country first to reduce what is hitting authelia though.
INF ts=1730043575.319679 msg=using config from file file=/etc/caddy/Caddyfile
Error: adapting config using caddyfile: parsing caddyfile tokens for 'order': maxmind_geolocation is not a registered directive, at /etc/caddy/Caddyfile:5
v2.8.44. How I installed and ran Caddy:
OS: linux x86_64 QTS 5.1.7
Docker version 20.10.27-qnap1, build 662936b
Run through portainer as docker-compose
image: serfriz/caddy-crowdsec-geoip:latest
- PUID=1001
- PGID=1000
- TZ=America/Toronto
- CROWDSEC_API_KEY=xxxxxxxxxxxxxxxxxxxxx
- 443:443
- 443:443/udp
- /share/docker-apps/caddy/Caddyfile:/etc/caddy/Caddyfile
- /share/docker-apps/caddy/data:/data
- /share/docker-apps/caddy/config:/config
- /share/docker-apps/caddy/logs:/var/log/caddy
default:
email my@email.com
order maxmind_geolocation first
order crowdsec after maxmind_geolocation
crowdsec {
api_url http://crowdsec:8080
api_key xxxxxxxxxxxxxxxxxxxxxxx
(geofilter) {
@mygeofilter {
not maxmind_geolocation {
db_path "/config/GeoLite2-Country.mmdb"
allow_countries CA
not remote_ip 172.29.20.0/22
respond @mygeofilter 403
(secure) {
forward_auth {args[0]} authelia:9091 {
uri /api/verify?rd=https://auth.domain.com
copy_headers Remote-User Remote-Groups Remote-Name Remote-Email
auth.domain.com {
reverse_proxy authelia:9091
news.domain.com {
crowdsec
output file /var/log/caddy/miniflux.log
import geofilter
import secure *
reverse_proxy miniflux:8080
